Where do I secure the seat belts on my 58 Caddy?
Discussion in 'The Hokey Ass Message Board' started by Louie T, Jun 19, 2013.
  1. Louie T
    Louie T
    I'm putting in some seat belts in my 58 Caddy and I don't know where to fasten the belts on the center of the front seat. I can see the eye hook where the outer belts secured to the pan. One of them even has an old seat belt hooked to it. Am I missing something for the other half of the seat belt?
  2. Roger Walling
    Roger Walling
    Look under the floor for a reinforced area near the drive shaft tunnel.
  3. HOTRODPRIMER
    HOTRODPRIMER
    You can use them most anywhere but don't mount them to the frame,,in a accident you will want the floor to give,,also use big washers under the floor. HRP
  4. Louie T
    Louie T
    Ok. So secure them to the pan?
  5. HOTRODPRIMER
    HOTRODPRIMER
    Yes. HRP
  6. Louie T
    Louie T
    Ok. Thank you.
  7. Rusty O'Toole
    Rusty O'Toole
    Secure to the pan and use a 6" wide steel plate or big thick washer for extra reinforcement. If you inspect the pan from underneath you may see bolt locations stamped in the pan. Seat belt mountings became mandatory in 1963 but some cars had them earlier.
    While you are at it, be sure to reinforce the seat mounting bolts. On older cars the seat can tear loose and squash you against the belt in severe accidents.
  8. falconsprint63
    falconsprint63
    from Mayberry
    like hrp says pan and big *** thick washer
  9. Louie T
    Louie T
    Lol. I think I have a few of those laying around. Btw, what's the "hrp" ?
  10. best2923
    best2923
    from north Id
    Whats a seat belt. They don't require seat belts on pre-64 in Idaho.
  11. dadseh
    dadseh
    Gene pool must be gettin a bit thinner by now!!
  12. MO_JUNK
    MO_JUNK
    from Rolla, Mo.
    Check your seats before you drill holes in your floorpan. I'll explain. I recently purchased a 58 Biscayne with all original interior. I purchased the chrome latch type belts from Speedway. I had my holes all laid out and was getting ready to drill for the center anchors. I decided to check the seats. There's no way to snake the belts through the seat. I would have had to cut the seat bottom for a belt p***age. I decided not to do that. It's original material. Your Caddy seats may be constructed differently. Just saying it would be wise to check first. Sam
  13. 40FordGuy
    40FordGuy
    Put 'em in !!!!!!!!!! 3 pointers, for my 40 pickup !
    4TTRUK
  14. Fenders
    Fenders
    Original seat, or your life.....
    yup, tough choice.
  15. HOTRODPRIMER
    HOTRODPRIMER
    Actually,All cars built after January 1, 1968 were required to have seatbelts here in the States but your right most did have anchor points from 63 on. HRP
  16. Streight8
    Streight8
    juliano's sells some nice plates for the purpose. They have a large radius rounded edge so the chance of them "cutting" through the floors is much less than using simple large flat washer. Proper bolts included don't scrimp on safety. http://www.julianos.com/anchor_plate.html
  17. 2racer
    2racer
    Just be a hillbilly and run a rope under the seat and tie a bowline knot to cinch it up...
  18. Louie T
    Louie T
    Lol. Actually I was gonna run some bailing wire and just twist it up and drive.
