Where do you all pick up random oddball brake fittings?
Discussion in 'The Hokey Ass Message Board' started by tlmartin84, Jun 1, 2013.
  1. tlmartin84
    tlmartin84
    from WV
    I have a box with tons of fittings but can't find a specific tee that I need. I can't find them at the big stores (jegs, speedway, etc).
    Anyone have a site that has a ton of brake line fittings???
  2. Harvey29
    Harvey29
    from kansas
    what threads do you need?
  3. NAPA. Weatherhead catalogue.
  4. 63comet
    63comet
    I've used pipe male to female flare fittings from NAPA combined with hardware store fittings to get the right T fitting in the past. Or did they all come from Ace?
  5. 39 Ford
    39 Ford
    I needed a tee 3/16 -1/4 and 1/4 the other day the NAPA guy put one together. This was for brake lines. NAPA is the place.
  6. Red Weaver
    Red Weaver
    try the closest hydraulic shop that sells parts. If I can't find exactly what I want I take 2 halves of the parts that will work and tig weld them together. I use .040 tungsten and turn down to about 25 amps
  7. 296 V8
    296 V8
    from Nor~Cal
    NAPA
    Then when you’re at the self serve wrecking yard with time to burn …. Strip a bunch of random ones off for someday.
  8. An old timey repair shop, if ya can still find one.
  9. chopolds
    chopolds
    from howell, nj
    Discount Hydraulics, in PA. I bought about 50$ worth of differetn brake fittings a long time ago, and still have quite a bit left. AND I've never been stuck with not being able to finish a job, I always have that odd fitting in stock!
  10. hot rust
    hot rust
    i get all my unusual stuff @ godman high performance in memphis tenn. ray godman is the owner and you might remember him from his top fuel cars the tennessee boll weevel. don't have a # handy but you should be able to google it.
  11. gimpyshotrods
    gimpyshotrods
    NAPA. They just point at the bins behind the counter, and let me do my thing. I write down my part numbers, and quan***ies, so they can ring me right up.
  12. gasserjohn
    gasserjohn
    online/quick! delivery....mcmastercarr
