Technical Where does this go?
Discussion in 'The Hokey Ass Message Board' started by JorgeFleet48, Jul 13, 2023.
  1. JorgeFleet48
    JorgeFleet48
    Folks
    As I begin gathering everything to reassemble my chevy 235, I came across this round part. I can't remember where it came from for the life of me. Any ideas?
    dana barlow likes this.
  2. rusty valley
    rusty valley
    Looks like a splash thing that would go on the front of the crank, next to timing gear. but..I am no 235 expert
    JorgeFleet48 and dana barlow like this.
  3. dana barlow
    dana barlow
    from Miami Fla.
    Ya,inside* timing cover on crankshaft*. It is designed too help front oil seal last longer. After the rest of engine is together an timing cover is on with seal,the front pulley goes on an bolted=that then holds it between pulley an crank.
    Some call that a slingring. The flair faces out away from crank so the pulley snout goes through seal an push's the center of ring to the timing chain gear.
  4. SEAAIRE354
    SEAAIRE354
    Don’t feel bad. You are far from the first guy to forget to put it back on.
  5. JorgeFleet48
    JorgeFleet48
    thank you all...... again
