Where have all the 4 speeds gone?
Discussion in 'The Hokey Ass Message Board' started by tray502, Nov 6, 2011.
  1. striper, that is awesomw shot of the car, thank you! I love it! But I am disappointed of no build thread or photo album so that I can look at it more.
  2. dana barlow
    dana barlow
    from Miami Fla.
    Use to be it was trick just to have over drive on my threespeed,than the 4 speeds were thye deel and now we 5speed and even 6.
    Time just rolls by
  3. Jimmy2car
    Jimmy2car
    from No. Cal
    This is my 32 Tudor inside. Flathead to Toploader 4 spd to Gear Vendors Overdrive. ****on on shift knob triggers Overdrive. Wires are inside the shift lever which is a Model 60 Marlin .22 gun barrel.
  4. A-Bomb
    A-Bomb
    Three Pedals fit just fine in my 31 coupe !! As a matter of fact, I took the car out for a ride and yanked it around some today !!
  5. badlefihand
    badlefihand
    Muncie
      510.5 KB
  6. kwmpa
    kwmpa
    from Pa
    Where are the "stromburg" carbs your using they sound like a rare duck might have to throw my strombergs in the junk pile and get some of those
  7. Hotrodbuilderny
    Hotrodbuilderny
    4 speed in most, and 5 extra muncies, and 4 ford 4 speeds in the ba*****t.I was going to make my 41 ford truck a 5 speed, but went out and bought a 3 speed for the back of my y block to have three on the tree
  8. Ha Ha Ha yea true! :D
    But with a stick you can watch her bat herself silly everytime you wack a gear! :eek: :D
  9. storm king
    storm king
    Whatever I drive, I want to be able to race. Simple economics. Four speeds are too expensive to put together right.
  10. my truck has a 4sp and i have 2 muncies and a T10 under the bench
  11. "Three pedals and a stick" in my '34 Ford 5-window Coupe. You can't say that I'm "shiftless"!
    Jim
  12. HotRod33
    HotRod33
    read the rules for the HAMB.... doesn't it say to do an intro....? Rules:
    1. No profanity in subject lines
    2. No political/religious/racial posts
    3. No ****.
    4. All personal information listed on this board is private and protected. The HAMB does not sell this information and you are not privy to use it for your own reasons. Test us on this one and we will bite.
    5. New Users must fill out thier profiles. Every bit that you can. Simply click on "User Cp" above and get to work.
    6. New users must introduce themselves in the intro forum.
  13. Cruiser
    Cruiser
    When it comes to an automatic or a stick, I say to each his own, they both have there place and work well. A hot rod would be a lot of fun with a stick and a cruiser (custom) with an automatic. Being a cruiser I'll stick to an automatic and let the hot rodders burn the rubber. :D
    CRUISER :cool:
  14. fab32
    fab32
    Used to drive nothing but 4 speeds, then got lazy after the knees started to go. Now I've got two new Doug Nash 5 speeds waiting in the wings since the double knee replacement was so successful. One will go in the BBC "32 5w and the other might find it's way into the planned Nascar 9:1 SBC powered modified. Got plenty of Muncie and Ford top loader 4speeds in the stash for any future builds. The "32 2dr (avatar) will probably keep the T-400 that's currently in it, I'm still lazy.:eek::cool::D
    Frank
  15. The Shocker
    The Shocker
    Agree totally .A basic stock 4 spd (Muncie /Toploader /833) will hold up in a 13 second car with limited traction.Now stick that 4 spd in a car that has enough motor to dip into the low 11's with slicks that will dead hook and its so long factory 4 spd .My PG in my dragcar takes a beating and keeps on going ...
  16. Algon
    Algon
    I run toploaders in everything.....Nothing like a 60's 4speed and a properly tweaked shifter but I just can not get into all this t-5 stuff. I didn't grow up on Honda's so that "pro- billet/short throw/stick in a puddle of mud" feeling is just out of place in hot rod.
    No kidding automatics are cheaper, just like building sbc's... that doesn't mean you have to use one.:rolleyes:
    Really what bummed me out was when we were first starting to get UMTR guys in the shop talking stick shift this and stick shift that. I was thinking cool, S/S is back....... when here they allow Libertys and Lencos. Cool but not the full manual only racing I hoped for.
  17. Kerry
    Kerry
    Guys, if you want the thread to get locked down keep up the drama. Get it?
  18. willowbilly3
    willowbilly3
    from Sturgis
  19. Fiorano
    Fiorano
    i prefer the connection and the activity and experience of driving a manual trans. its fun.
    i have a four speed muncie for sale too, i got nothing to put it in- but for all the questions no one wants it.
    i think a T-5 works great though the 5th slot to slam the gear into is just such a good idea.
  20. dirty old man
    dirty old man
    The 31 "A" roadster I've almost completed has a Ford Toploader with a Jeep Tremec 4 speed shifter cover where the top plate normally goes. This gives the appearance of a top shift early Ford trans. Rest of driveline is SBC with McCloud safety bell hsg. which has a**** others, a Ford trans bolt pattern, and a 3.70:1 9" rear.
    I have another toploader that has never been installed in a car, maybe one day I'll install a Gear Vendors overdrive on it and put that in the roadster.
    It is quite tight around the pedals, especially with my size 14 shoes.
    Dave
  21. 59Custom300
    59Custom300
    I put a stick in the old 59. It ain't a hot rod without a clutch in my opinion. As a matter of fact, when I went looking for an old car to buy, I wouldn't look at anything without a stick shift in it already. I wanted to make sure I didn't have to go hunting for the proper clutch set up.
  22. Several in my rides!
  23. OneBad56
    OneBad56
    Could always install an hydraulic clutch set up, just like stomping on a power brake pedal.
  24. OneBad56
    OneBad56
    4-speed with a overdrive = 5 speed.
    also threw in a hydraulic clutch set up so I didn't have to change gears with 2 feet on the clutch.
  25. iammarvin
    iammarvin
    from Tulare, Ca
    Tray......newbie.......buddy.....(insert best C. Walken imatation here) I like you......but.....you are not being to respectful. (No more bad sound effects) There are more rowers of the oares on this site then all the skullier teams in North America.
  26. uwonamos
    uwonamos
    from Omaha, Ne
    I did an 18 spline hemi 4-speed in my 55 G***er. The snout was already turned down for a chevy throwout bearing so I was able to use a hydraulic one. Really helped with the linkage & works great. Oh, and it happened to have an old set of Liberty Race cogs in it. I don't mind holding it in gear when cruising. :D
  27. lurker mick
    lurker mick
    32 3-window + 388" small block + early Muncie 4-speed = fun ride.
    Mick
  28. stillrunners
    stillrunners
    from dallas
    sold a mopar 4 speed 833/OD tran with bellhousing and shifter for $250 yesterday for a early 40's Dodge truck build....was a buddie deal...
  29. VonKool13
    VonKool13
    He didn't do an intro Newbie! We don't take kindly to people whom we don't know anything about coming on here and talking ****. eg. automatics are bad and sticks are Real Hot rods. He needs to respect the RULES just like you do.
    I think he posted this to stir the pot, he hasn't posted since and hasn't shown any car or parts to his car. IMO he needs to go away.
  30. Kerry
    Kerry
    Quite frankly you seem like a newbie to me. Stupid intro police. He has an opinion and the balls to share it. Good for him.
    I take it you're driving an automatic and have to defend your manhood? Lighten up Frances.
    Now shut up about the stupid intro and let's get back to transmissions.
