Technical Where/how can I get Ford rear drums turned?
Discussion in 'Traditional Hot Rods' started by Barry in Ohio, Oct 30, 2025.
  1. Barry in Ohio
    Barry in Ohio
    Hello!
    Folks have been very helpful identifying the various parts on my cobbled together early Ford Sports Racer and I am hoping that you can solve another roadblock. I am trying to keep the car as close as possible to the original 1953-54 build.
    I was able to get the front drums turned but I am running into roadblocks getting the rears turned.
    The car is based on a 1937 Ford ch***is, and the few auto parts stores that turn drums around here (Columbus, OH) can't do the rear drums with the one piece hubs, because the center hole is considerably smaller than the mandrel on the AMMCO and Bosch machines in the stores, so the drums won't mount. I sourced a spare axle, hoping that someone could hold it in a 3-jaw chuck, but I haven't found anyone with that setup yet.
    Any suggestions? Thanks in advance for your thoughts!
    Barry in Ohio
    down-the-road and Tow Truck Tom like this.
  2. MrMike
    MrMike
    Find a shop that can cut air cooled VW rear hubs, they can do them, if the other shops you tried have Ammco brake lathes it should be a matter of just changing the machine arbor if they have the small arbor on hand.
  3. lostone
    lostone
    from kansas
    If you know anyone that works at a machine shop, probably do it on a lathe....
  4. Barry in Ohio
    Barry in Ohio
    Thank you for the suggestions. I will give these a try. :)
    Tow Truck Tom likes this.
  5. Adriatic Machine
    Adriatic Machine
    I made an adapter for a friend of mine to do this job. He owns the machine but it wouldn’t accept the rear drums. Actually
    Actually he mailed me one of the sleeves and I modified it with an OD chamfer that met the ID. I’ll see if I can find a picture, it was super simple.
  6. RICH B
    RICH B
    Here's a picture of the small OD arbor for a Ammco brake lathe. Maybe show it to the guy at the shop; he might have it buried under other tooling; but unaware of what it is for. Otherwise the previous suggestion of a VW shop might work.
    Something else; make your machinist aware that early Ford drum material is "valuable" and he doesn't have to be overly aggressive and turn every groove/mark totally out of the drum for it to function.
  7. Mr48chev
    I've worked in a number of shops with Amaco brake lathes over the years an not one of them had a secondary arbor except the one that came on the machine. An automotive machine shop that does a lot of different drums and rotors might but finding one of those now is a challenge.
    Rehpotsirhcj and SS327 like this.
  8. Annette Chaplin
    Annette Chaplin
    Champion Brake and Driveshaft of Grafton West "By God" Virginia! Has been turning brake drums since the '60's. Just a small "Mom-Pop" shop out behind the house type of deal.
    They turned the '39-'42 Rear brake conversion on my original, early production '32 'hind end.
    Around a 3 hour drive from the middle of Ohio,,,,,,.
    winduptoy, pprather and down-the-road like this.
  9. Deke
    Deke
    Sounds crazy but my local Oriellys did my 37 drums and actually got it right for like $20
    winduptoy, pprather and Driver50x like this.
  10. Barry in Ohio
    Barry in Ohio
    Thank you folks for all the suggestions! I will start by calling the local O'Reilly's, but the ones that I visited had the larger arbor mounted. Perhaps the smaller one is lurking in a drawer. I will show them Rich B's photo...
    Next I hope to get a peek at Adriatic Machine's adapter and get a machine shop to turn one down.
    Failing that, I'll fill up the gas tank and hit Champion Brake and Driveshaft in WV unless someone else chimes in with a closer option.
    I greatly appreciate all the comments. :)
    winduptoy likes this.
  11. Barry in Ohio
    Barry in Ohio
    Just a quick update for anyone who might be looping back. I struck out at the 2 closest O'Reilly's for the smaller OD Ammco arbor, and then started calling vintage VW shops. No direct hits there, but one friendly owner referred me to Complete Brake Service in downtown Columbus and they had an arbor that fits, so I made it past that hurdle.
    I won't be able to stop back and pick up the drums until the week of Nov. 10 but I will update the story then. (I have picked up the drums, untouched, twice already from folks who thought that they could turn them but couldn't) Here's hopin'
    Thank you again for the suggestions!
  12. 51504bat
    51504bat
    Can they arc the shoes ad well?
  13. Deke
    Deke
    Funny when my Oriellys did mine they had to "wait till the old guy came in cause they couldn't figure out how to mount them"
    Old guy probably had the arbor in his drawer I guess.
  14. MrMike
    MrMike
    What's going to happen when all the old guys are gone? and yeah, I fit that description. p*** the knowledge on while you can.
    Andy likes this.
  15. lostone
    lostone
    from kansas
    Sadly a lot of the younger people have no interest in leaning what we know.
    That's one thing that really saddens me, got no one to p*** all my years of experience and knowledge down too.
    The shop I worked at for almost 40 years tried to find and hire someone I could teach and train frame repair too but when we could find someone after a couple months they decided it was too hard and quit.
    I've had numerous people and shops I've dealt with for years ask me what are they going to do once I retire....
    Andy, RICH B and BigRRR like this.
  16. trucker1
    trucker1
    What about cutting the wedged studs out and convert the drums to slip on. Use a 5/8" hole cutter and some newer press in studs. There's video on U tube about it.
  17. Barry in Ohio
    Barry in Ohio
    51504bat - I will ask about arcing the shoes when I am back in town and let you know.
    Deke/MrMike/lostone - yes, I see some of this where I am in Central Ohio. But, encouragingly, one of the O'Reilly's guys was in his 30's, and we have a few 20-somethings pursuing their grandfather's interests in hot rod. One drives his Model A roadster to work most days of the year.
    truckerl - I did see that YouTube video. My drums mount inboard of the hubs so that the studs are swedged into the hub flange. I could do the conversion but the drums still wouldn't slip off after the newer studs were pressed in.
    Barry
  18. 29Sleeper
    29Sleeper
    from SoCal
  19. Barry in Ohio
    Barry in Ohio
  20. HOTRODPRIMER
    HOTRODPRIMER
    A lot of old school automotive parts dealers that have been in the business for a couple of generations will have the equipment to turn your drums, as big as Ohio it shouldn't be a problem to find a parts house or a small garage that can do the job. HRP
  21. Barry in Ohio
    Barry in Ohio
    Thanks HRP! I was able to locate a place in downtown Columbus called Complete Brake Service, and I dropped the drums off last Friday. I’m not back in town until this coming Monday, so I will see if they were able to complete the job. (They suggested that they could when I dropped things off, but I’ve brought the drums home unturned twice before, so we’ll see.)
    Regardless, I will post here and let you know. If unsuccessful, I’ll start with the local Model A club, as suggested by 29Sleeper above.
    Thanks again for the suggestions!
  22. Barry in Ohio
    Barry in Ohio
    Follow-up post for anyone who is checking back. Complete Brake Service on Town St. in Columbus, OH WAS able to turn my 1937 Ford rear drums/hubs, as well as a similar 9" pair from a 1951 Studebaker that had me stumped for well over a year.
    They were willing to follow Rich B's advice that old Ford brake drum material is valuable and therefore they didn't take out the last few thousandths of the deepest grooves, but the drums are smooth to the touch.
    pprather, Budget36, Packrat and 2 others like this.
