Hot Rods Where in the #@%% do these Model A Ford brackets go?
Discussion in 'The Hokey Ass Message Board' started by -Brent-, Mar 10, 2021.
  1. -Brent-
    -Brent-
    These came off my car, I figured it was when we did the firewall flip. But the floor had been replaced, too, so, maybe it's from somewhere like the B-pillar area. I don't have a clue and I've spent the better part of 2 hours searching and then zooming in on photos.
    Thanks for your help!
    Brent
    20210305_134610.jpg 20210305_134628.jpg 20210305_134634.jpg 20210305_134648.jpg
    Stogy likes this.
  2. Stogy
    Stogy
    Maybe the top inner corners towards header panel?...a big maybe...
    The silver lining is you have them...
    -Brent- likes this.
  3. Stogy
    Stogy
    Maybe lower forward cowl inside or even outside...
    Paging @Fitnessguy
    AVater and -Brent- like this.
  4. -Brent-
    -Brent-
    I just went out and checked. They don't go anywhere around there. I have the header to side wood brackets in. Based on the surface rust, that the sand blasting couldn't get to, I ***umed somewhere around the bottom perimeter of the subrail-body.
    We were smart and marked them with numbers that make no sense... hahaha.
    Stogy likes this.
  5. -Brent-
    -Brent-
    Is @Flop around? He's touched every square inch of a Model A.
  6. Stogy
    Stogy
    I have complete confidence this will be repatriated...with a few f words in between...maybe you'll even have matched numbers once you find that sweet spot...
    -Brent- likes this.
  7. Stogy
    Stogy
    Maybe elsewhere but he's been quiet here...
  8. kidcampbell71
    kidcampbell71
    Ha !! @Flop has gone Amish. Wood worker, tiling artist .. and a legit tree chopper.
    His Instagram is hilarious. All his home & outside projects .. ( & they're really good ) .. .. I wanna' ask how much is the chop ?
    He's having fun as a home owner. Hit him up on IG. Yes. He'll know, but an *ss load of people here would, too.
    @sloppy jalopies
    tb33anda3rd, Stogy and -Brent- like this.
  9. Stogy
    Stogy
    :rolleyes:...mmmmm....maybe...this area is heavily modded many times...and is pretty beefed up into the subframe for cowl adjustment...​
  10. Corn Fed
    Corn Fed
    They go on the back side of the B pillar. The smaller side 3 bolts line up with holes in the pillar. The longer side is horizontal below the quarter window. Your quarter wood can tie into it.
    If you have a 30-31 they really arent needed. They are more structural in a 28-29.
  11. Almostdone
    Almostdone
    I have a ‘31. Never saw anything like those brackets. Flipped my firewall too. I was wondering if they were a ‘28-29 thing, as @Corn Fed eluded to. Or maybe I just never removed them.
    John
    Stogy likes this.
  12. Stogy
    Stogy
    :rolleyes:...I think you nailed it...Cornfed...am I reading the correct location?
    Hotrodmyk, rusty valley and Tim like this.
  13. Tim
    Tim
    from KCMO
    Clicked for the hilarious ***le lol glad it got sorted. Haven’t seen anything from flop on IG since October ish
    -Brent- and Stogy like this.
  14. Corn Fed
    Corn Fed
    Yep thats it.
    lothiandon1940, -Brent- and Stogy like this.
  15. Stogy
    Stogy
    They probably strengthen/beef up the latch area so maybe a good thing to buckle in if you have it...
    Hnstray likes this.
  16. -Brent-
    -Brent-
    @Corn Fed is a ruler!!!!
    Thanks man!
    And thanks to everyone else, too.
    For those searching in the future: we'll call these B pillar to quarter window brackets.
    I'm thrilled to have this mystery solved!
    Corn Fed, I owe you one.
  17. Corn Fed
    Corn Fed
    No problem! Every now and then being a Model A nut pays off.
  18. jimmy six
    jimmy six
    You can’t miss them they go on the {#%^*~<>€}#%<{ in the 3 holes I believe with rivets. :rolleyes:
    -Brent-, kidcampbell71 and Stogy like this.
  19. Fitnessguy
    Fitnessguy
    My coupe didn't have them. The guy i bought the car from probably stole them....Never trust an east coaster! :D My wood kit is a little different as well as i don't have that bottom wood piece that the bracket would attach too.
    -Brent-, Stogy and harpo1313 like this.
  20. Stogy
    Stogy
    :eek:...Waaaa!!...I honestly can't even remember whether if they were there either...it truly is easy to see how serious head scratching can evolve with the good Ole Blueprints with either the wood or the body's...who knows maybe from that piece downward is the mid door wood kit...
    I sure as heck hope I don't find them...if I do they'll be on the UPS express asap...:oops:
    kidcampbell71 likes this.
  21. Fitnessguy
    Fitnessguy
    [emoji23] all good brother, I didn’t need them anyways and if I did I’d just fab my own cause I got those skills!!
    Stogy likes this.
  22. warhorseracing
    warhorseracing
    from cameron wv
    @-Brent- WHERE IN THE #@%% DO THESE MODEL A FORD BRACKETS GO?
    You could check with the guys over on the Vintage Ford Forums. They are some serious Model A guys there.
    -Brent- likes this.
  23. Stogy
    Stogy
    -Brent- likes this.
  24. -Brent-
    -Brent-
  25. A 2 B
    A 2 B
    from SW Ontario
    Showing how they are fastened. They provide extra support for the wood and panel . This pic is from a '30 coupe. DSC06382.JPG
  26. Stogy
    Stogy
    @A 2 B, are those 3 Countersunk stove bolts running through the entire post and wood via the latch side? I'm suspecting yes...thanks, that gives a great visual on install and hardware...
  27. A 2 B
    A 2 B
    from SW Ontario
    DSC06386.JPG DSC06381.JPG DSC06386.JPG DSC06387.JPG I t DSC06388.JPG hink so. I will know better when it is dismantled further for blasting. I have other pics that might show better. DSC06381.JPG
  28. A 2 B
    A 2 B
    from SW Ontario
    The 3 Thru bolts seen from the door Jamb. The small curved transitional piece is fastened with 2 wood screws into the other wood support piece from underneath which in turn is held on by 2 wood screws going thru the support bracket from the underside.
    Stogy likes this.
  29. Stogy
    Stogy
    Thanks A2...that clarifies it all in a nutshell...those two wood screws going upward probably took their toll with skinning knuckles installing them...that and the pics will certainly be a helpful resource for those tackling the interior of these very plentiful A-Bones...
  30. Now put them on a shelf somewhere that you won't be able to find them when you want them a few months from now. :D
    -Brent-, loudbang and Stogy like this.
