where is my 53 Ford custom? Found!!
Discussion in 'The Hokey Ass Message Board' started by ss34coupe, Nov 5, 2007.
  1. leadsled
    leadsled
    Had that same problem, I dealt with the manufacture of the springs in St Louis instead of Jamco (that is another story) Mine were off by about 3/4", I knew it because my driveshaft would not fit. Anyway the owner of the shop in St Louis made it right.
    I took the spring stack up apart and sent him the top spring.
  2. ss34coupe
    ss34coupe
    No plans to round the hood corners, going to leave it this way for now. Still lots of work to do on this custom, but it will have to wait because I am back on my 33 five window project. Like my grown kids say "it never ends!"
  3. ss34coupe
    ss34coupe
    Leadsled - you say the springs were off by 3/4" - meaning the mainspring was too long by that amount? Or did your spring position the rear axle ***embly too far to the rear by that amount?
    Thanks for your input on this problem!
  4. leadsled
    leadsled
    34coupe,
    It positioned my rear axle ***embly too far forward. (I think) what ever it was it was obvious it was wrong. What was interesting is the man at the shop that built them stated he had made many to Jamco's specs and never heard of the problem. I'll see if I have my emails they had measurements.
    Tim
  5. ss34coupe
    ss34coupe
  6. aussie57wag
    aussie57wag
    from australia
    302 and auto is bit of a let down. I understand though if you have a tight budget and cant afford a cool period engine like a flat head or y-block 3 speed column shift. Cool car though. Good on you for finding it. Look forward to seeing it finished.
  7. ss34coupe
    ss34coupe
    aussie57wag - I look forward to seeing the custom finished as well, but the project is on hold for now while I put together my 33 Ford 5 window coupe - that one does have a period motor - a 331 Cadillac.
    Thanks for your comments!
  8. leadsled
    leadsled
    dug thru my emails no luck.
  9. ss34coupe
    ss34coupe
    Thanks for looking. Good luck with your car.
  10. ford495051
    ford495051
    I really dig your project. I hope you post some progress pictures when you get back on it. Nice job.
  11. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    I noticed that you have not done anything with the headlights. Old school trick is to mount the headlight bucket from the back instead of the front. Weld the trim ring to the fender. Give it that tunneled look.
  12. ss34coupe
    ss34coupe
    Thanks! I like the car in your avatar, looks to be the same color my 53 convertible was as shown in the pics earlier in this thread. Hopefully will get back to this project soon, right now there are three others to deal with as well.
    Will be doing some more mods on this one before it is ready for paint - thanks for the comment!
  13. ss34coupe
    ss34coupe
    I stalled on this rebuild, but fortunately the son of fellow who built the custom in the early 60's (with some help from his brothers) has picked up the project. So it is going back to the original builder's family, where it should be. Shane is showing a lot of enthusiasm for the project, and has already picked up a motor, trans, wiring kit and other parts to put the old custom back on the road. Here are a couple of pics - the first shows the custom on the ferry going back to the mainland, and the second shows the car in Shane's shop. IMG_20190330_185037.jpg IMG_20190430_202226.jpg
  14. HOTRODPRIMER
    HOTRODPRIMER
    Like many major rebuilds the start and stall, and start again, keep us up to date. HRP
  15. Shanemade
    Shanemade
    Thanks for everything Steve! Glad this car is back in the family, longways to go on it. I will be getting to work on it very soon been a long six weeks making room for it.
    chryslerfan55, 62hotcat and PBRmeASAP like this.
  16. ss34coupe
    ss34coupe
    Keep us posted on your progress, Shane. Your 53 Ford convertible is an important part of British Columbia's custom car history.
  17. Shanemade
    Shanemade
    Ok, so been pretty busy on this! I bought a donar 01 Mustang for the transmission and a bunch more parts, seats, brake system the list goes on. I also have acquired a 351W. I bolted them together and all is good until I go to mach up the mounts and trans mount. Anyone put a 351W in a 53 Ford? I'm sure it has been done. The oil pan is definitely not going to work. the motor came out of an 89 Crown Vic. Any suggestions on the oil pan? There was a post on here regarding Butch's motor mounts and headman headers 88400's https://www.jalopyjournal.com/forum/threads/sbf-in-1953-ford-customline.988618/ great info. My question is will these bolt up to my 351W ? Here are a couple pics of where I'm at. any help would be greatly appreciated. IMG_20190519_162634.jpg IMG_20190519_162641.jpg IMG_20190519_162655.jpg IMG_20190519_162752.jpg IMG_20190519_162634.jpg
  18. Crocodile
    Crocodile
    Check the shape and dimentions on a 351W pan to fit an Econoline van. Not sure if it will be much different than your Crown Vic pan, but they are a rear sump. 4x4 pickup is also a possibility to check. Most Ford p***enger car pans are front sump. and what you have looks to be a dual sump, similar to a fox ch***is 302.
  19. Shanemade
    Shanemade
    looks like I'm going to try this out...I do not think there is any way around notching the cross member. but will have room to move back another inch and some clearance. Thanks for the suggestion.
  20. Shanemade
    Shanemade
    So here is a bit more info on the Pacers car club. My uncle (Jim Jameson) came by yesterday to check out the car and brought by some memorabilia.
    ss34coupe and 62hotcat like this.
  21. Shanemade
    Shanemade
    Just going to leave this here!
    oliver westlund likes this.
  22. ss34coupe
    ss34coupe
    Shane - good to see you are going back to the shade of blue that your Dad used. Looks good!
  23. oliver westlund
    oliver westlund
    subscribed! im customizing a 53 for a surprise bday gift for my dad, my first car was a 54, live em
  24. Shanemade
    Shanemade
    Thanks Steve! I have been quite busy. Had some time between parts coming in. I pulled the rear end and felt I needed to move the perches so I moved them in 3/4 on each side. Worked out well. Then I started thinking about brakes.... Pics say the rest.
  25. Yep only pan that works!
    Sent from my SM-G988U using The H.A.M.B. mobile app
