1952-59 Ford Where is the T 85 trans fill plug located?
Discussion in 'Off Topic Hot Rods & Customs' started by mikhett, Jun 3, 2023.
  1. mikhett
    mikhett
    from jackson nj
    I have a t 85 ****** on the bench and I see two plugs which one is the fill plug ?I have the shop manual but it doesn't show it? Thanks
  2. TomDobbs
    TomDobbs
    It's on the right side, up high. There's usually an access hole under the carpet on the trans tunnel that has a rubber plug in it. If you have overdrive there is a second, smaller fill plug on the OD section. The proper fill method is to fill the transmission first, then top up the OD.
  3. mikhett
    mikhett
    from jackson nj
  4. mikhett
    mikhett
    from jackson nj
  5. TomDobbs
    TomDobbs
    Glad to help.
