Technical Where? sheet metal angle.
Discussion in 'The Hokey Ass Message Board' started by chopolds, Nov 14, 2023.
  1. chopolds
    chopolds
    from howell, nj
    I have a few small pieces of 1/2 x 1/2" sheet metal angle, in the shop. Don't know where or when I got them. But I would like to buy more, and maybe in 3/4" and 1". 16 or 18 gauge. I can only find 1/8" on all the websites. Anyone got a source?
    Yes, I know I can bend some up on my brake, but it doesn't produce the crisp edge I need for some jobs!
  2. In_The_Pink
    In_The_Pink
    Metal shelving and filing cabinets are one source, but you get what you get when it comes to flange widths, etc. I haven't seen "off the shelf" pieces of pre-bent 16 0r 18 gauge sheetmetal sold anywhere, but maybe a local fabricator could bend some up to your specs.
    williebill likes this.
  3. FrozenMerc
    FrozenMerc
  4. theHIGHLANDER
    theHIGHLANDER
    Hardware suppliers or farm stores. A couple of mine have odd small gauge ****. Can't raise a rt hand to what but I've done it weekends and after hours
  5. williebill
    williebill
    I needed bigger angle than that, something like 1 1/2" or bigger, in 16 gauge, and I couldn't find it either. So I bought thinwall square box and cut it into angle. Only way I could get what I wanted.
  6. Why, When and Where. I need photos! You guys know what you are discussing, yet I do not know? ? ? ? :confused: Sheet Metal Angle, I will inter web it, with image selected feature.
    A little later in search time ......... Now I need to buy a goniometer, to create my own custom Sheet Metal Angles.
  7. swade41
    swade41
    from Buffalo,NY
    Sharpone and williebill like this.
  8. Relic Stew
    Relic Stew
    from Wisconsin
    Buy square tube and cut it.
  9. patsurf
    patsurf
    since this is the second mention-how thin a wall sq tube can one buy? w/o some exotic stuff...
  10. nochop
    nochop
    from norcal
    Go to your local steel or welding shop. Mine has a complete shop and will fab up angle cheap. A lot of Guys forget that steel or weld shops do that. Pleasanton steel is my go to place for steel and will cut from a foot on up. A lot of times he will sell me drops cheap
    bobss396 likes this.
  11. chopolds
    chopolds
    from howell, nj
  12. flatout51
    flatout51
    A cheap break is a life saver. Make all you want.
    Tim and alanp561 like this.
  13. alanp561
    alanp561
  14. drtrcrV-8
    drtrcrV-8
    I know some of you will scoff at this source, but old bed frames are a good source of steel angles in a variety of widths & thicknesses! I keep an eye out on trash day, at recycling places, & just laying out where people do illegal dumping. It's been a source of raw material for a lot of projects over the years!
    lostone and ProtoTypeDesignFlauz like this.
  15. rusty1
    rusty1
    ^^^that stuff is tuff to drill,,,
    theHIGHLANDER and X-cpe like this.
  16. alanp561
    alanp561
    This guy seems to have the solution for your problem.
  17. Mr48chev
    A local place that I go to sell "drops" by the pound. They put the short pieces on a rack off where their chop saw is and most of us who go there look through that rack when we just need a short piece. The junk metal yard across town sorts out the good pieces that they haul in from the fab shops that they collect metal from around town.
  18. nochop
    nochop
    from norcal
    And no shipping!
  19. lostone
    lostone
    from kansas
    I use the **** out of bed frames! My mini mill table is all bed frames, so is alot of my shrinker/stretcher stand. I probably have 10 to 12 sets in the corner of my shop.
    It's high carbon content so it's tough to drill and welding it can be different.
    In_The_Pink likes this.
  20. bobss396
    bobss396
    We had a substantial sheet metal fab and ***embly shop at work until around 1995. These guys were artists and would adjust the back-gauge on a brake until they got what they wanted.
    We had a complex electronic ***embly that had a series of 3 trays that fit into it, called slices. They made it 100% in-house. Tolerances like +/- .010" were held to .002". On a spares job, we had some outside houses give it a go... it would not fit together once we got the sub-***emblies back.
