Where to buy AN fittings
Discussion in 'The Hokey Ass Message Board' started by Bluto, Oct 23, 2007.
  1. Bluto
    Bluto
    With this move I've no much time for real car building.
    I just looked at the prices of steel hose ends and fittings :eek:
    Looks like my long term-get everything place just added a 0 to the price of everything....... just plain steel not stainless
    Anybody out there know a good mail order place for this stuff?
    Does a -4 B-nut now really cost $7.00?
  2. Enginetuner
    Enginetuner
    contact Jason at ghx inc in Houston texas...713-939-7526, he can help ya
  3. Check out your local hydraulic shop. Parker and gates makes a bunch of fittings. They call them JIC not AN which means army/navy.
  4. jetmek
    jetmek
    try aircraft spruce and specialty. i cked their o/l catalog and found steel an-4 bnuts for 1.14
  5. alteredimage
    alteredimage
    I would say your local speed shop would be the best place. Most of them have it in stock or get deliverys daily. That way you can peice it together there instead of making a ton of orders.
  6. Try Speedway Motors, tell Bill the Speedwagen sent yah
  7. Bluto probably doesn't have a local speed shop,he is in Poland.;)
  8. SAVAGE
    SAVAGE
    Alliance Vendor
    Bluto has the largest speed shop in POLAND i bet
  9. 2002p51
    2002p51
  10. nexxussian
    nexxussian
    X2 for Aircraft Spruce, or if you plan on ordering ALOT, you might try Aviall. Their warehouse for Europe is evidently in Amsterdam (???).
  11. Bluto
    Bluto
    Thank you for the help so far
    I can get local fittings they are metric and aircraft rated and very spendy
    I'm use to JIC and AN stuff my tools for flairing and bending tube are inch based as are my taps
    And I have a lot of hose and tubing here
    You guys are right about us being the largest speed shop in the area. There is a Harley guy here but that's it
    Most people restoring here are using copper tube for fuel and brakes
    All that said I'm still having fun living in this little farm town
  12. FiddyFour
    FiddyFour
    holy schniekies Jim! glad to see ya doin well after yur move fella.
    listen, i know AN shit aint cheap but $7 seems kinda steep to me... lemme check locally an see what they fetch for steel ends and fittings...
    gimme a shopping list and an address in Poland and i'll see you get what you need pal
    Traves
  13. 19Fordy
    19Fordy
    From Wikipedia, the free encyclopedia:
    The AN thread is a particular type of fitting used to connect flexible hoses and rigid metal tubing that carry fluid. It is a US military-derived specification stemming from a joint standard agreed upon by the Air Force and Navy, hence AN.
  14. SinisterCustom
    SinisterCustom
    JIC and AN have different angles on the flare JIC=37*, AN=45*......generally JIC is for Hydraulics and are crimped on the hose, but there are reuseable Aeroquip JIC fittings (bulky).
    Both available at a hyd shop......or AN's can be bought through Summit or Jegs.
  15. stealthcruiser
    stealthcruiser
    Close....AN's are the 37 degree.
    Don't know about the JIC fittings.
  16. Bluto
    Bluto
    Nuts and sleeves will seal on both JIC and AN
    JIC is OK but you gotta watch how they plate em
    But the question still is where the best place to buy-em?
    I'm thinking about this cause I've got to brake plumb there cars here
    Yes...... just like wiring I do this from scratch
    On this last trip I got 125ft of tubing.....NAPA brake tubing in 25ft coils are great!
    Please remember I gotta import everything. BUT I knew that when I moved here.
    Customs is gonna crap it's pants when it sees a Blowen Ardun in a crate
    They all stood next to the Miller for photos when we rolled it outta the container!
  17. SinisterCustom
    SinisterCustom
  18. Mr T body
    Mr T body
    Alliance Vendor
    from BHC AZ
    Dave at Sweet Performance has great prices and goes out of his way to make sure it's RIGHT!
  19. Bort62
    Bort62
    JIC is the industrial standard based on AN. They are compatible, but JIC parts are not made to as exacting of standards (and as a result, cost less)
    JIC are fine for cars.
    www.mcmaster.com carries a lot of JIC parts.
  20. ditz
    ditz
    If push comes to shove call Godman's in Memphis TN. They have got the stuff and they know thier shit.
  21. MEDDLER1
    MEDDLER1
    we have a company in california called hose & fittings they sell mostly parker hanfin stuff.
  22. Paul2748
    Paul2748
    Earl's is a big manufacturer/supplier. Most speed shops carry parts, Summit and Jegs should have them.
  23. FiddyFour
    FiddyFour
    speed shop, rod shop, museum of FINE autos... Jim, show em all a pic of the Mas... that thing makes the lil' hairs on my neck go straight <img>
  24. spookydave
    spookydave
    Off the top of my head they cost well under 2 bucks for steel zink, alum (blue or red). I do have them in stainless also but those cost more. Still should be well under 7 bucks though.
    If I can help give me a call at 714 223 9322. Be sure to tell me you're from the HAMB.
    Thanks,
    Dave Bottomley
    Sweet Performance Products, Inc.
  25. FiddyFour
    FiddyFour
    viva la H.A.M.B.
  26. chilimac
    chilimac
    Genuine Aircraft Hardware is a great source for AN and other hardware.
  27. RugBlaster
    RugBlaster
    I've bought some very good plumbing supplies off of Ebay....USA, of course. ......I've got an idea some of the stuff for sell on Ebay makes it's way out of different facilities in lunch boxes.
