Projects Where To Buy? Custom Brake Hoses
Discussion in 'The Hokey Ass Message Board' started by blown240, Jan 1, 2009.
  1. blown240
    blown240
    from So-cal
    I need to get some brake hoses made for my 51 Chevy that I am putting disc brakes on. I know the length, and I know the fittings that I need. Is there anywhere near Huntington Beach, Ca that I can get some made?
    I need them to have the frame fitting on one end, and a Banjo fitting on the other end. I also need the banjo bolts.
    Also, what should I expect to pay for them? I am not if I should go steel braided or not, so what should I expect to pay either way?
  2. Stitchn
    Stitchn
    I am in Phoenix AZ, just had some made for my 32 pickup. It cost me $90 for a set. But made them while I waited.
  3. blown240
    blown240
    from So-cal
    Did you get rubber or steel braided? $90 isnt to bad.
  4. xtralow
    xtralow
    from So Cal
    You might give these guys a ring?
    Mesa Hose And Supply
    670 W. 17th, Unit G5
    Costa Mesa, CA 92627
    Tel: (949) 645-2661
  5. hemi coupe
    hemi coupe
    from so-cal
    You can also go to TMR in Orange, they are right around the corner from my shop. Good prices and great customer service!
    Jimmy White
  6. pasadenahotrod
    pasadenahotrod
    from Texas
    Lucky you! We just go to the CarQuest or O'Reilly's parts house, get the Brake Parts Illustrated catalog, find the hose with ends we need and buy them from there.
    There is a stock hose which can be used for almost every custom or conversion application.
  7. I would think there would be an OEM hose out there that would meet your needs. Try a good parts house with a knowledgable parts man. He might be able to pull what you need of the shelf.
  8. 5window
    5window
    Figuring this might be an important item and not knowing a lot about hoses but wanting them to be in full view, I just ordered braided stainless ones from Classic Tube. All was perfect and quickly shipped.
  9. moter
    moter
  10. flying clutchman
    flying clutchman
    The Napa Auto Parts by my house here in SD make them while you wait.
  11. knuckelhead
    knuckelhead
    from socal
  12. knuckelhead
    knuckelhead
    from socal
    try orme bros thay r in van nuys ca
  13. cretin
    cretin
    i just got an OEM hose from the local parts store when I put discs on the 54. They should have something that will work for you without having to custom order anything.
  14. i second that.......
  15. phat rat
    phat rat
    Look at it this way if you ever need one on the road do you want to have to find a place to have one made? Or do you want to be able to walk into a parts store and buy one off the shelf? I opted for off the shelf. If you go to a friendly parts store and ask to look at a brake parts book there is a section that has a description that includes type of ends plus length of all hoses. You just find what will work and it's OE application, that way no problem replacing it in the future
  16. most of the suppliers of aftermarket brake kits use as much oem parts as are available. why because custom parts cut into their profits and keep pricing low enough to sell their products.
  17. explodesmobile
    explodesmobile
    from seattle
    Hydraulic shops make em aswell.
  18. blown240
    blown240
    from So-cal
    Got 2 steel braided hoses made for $50 at mesa hose. Pus they did it while I waited in about 10 minutes. They needed to be longer than a stock hose because the car is bagged and they arent long enough.
