Making clutch overhaul and ****** was leaking.. then it lead to ****** overhaul... I found lot of newer ford 3-speed transmission overhaul kit. ( Incl all... ) Is there similar for 46 3-speed pick up open drive ****** ?? bearings at both end match according the hamb with 1939 ******. Also intrested to get modern seals. To both end of ******? Someone have numbers??? Timken, Skf or similar
