Hot Rods Where to get flathead front motor mounts
Discussion in 'The Hokey Ass Message Board' started by onekoolkat1950, Jun 25, 2016.
  1. onekoolkat1950
    onekoolkat1950
    Looking for where to find flathead front motor mounts. I don't know if these were a factory part or just aftermarket. If a factory part what years and models should I be looking for. Thanks in advance, Ray[​IMG][​IMG]
  2. Texas Webb
    Texas Webb
    Metal mount on the pump or the rubber biscuit?The rubber-speedway,Pete&Jakes etc.
  3. Flathead Dave
    Flathead Dave
    from So. Cal.
    I seen a pair on here in the cl***ified section. Can't for the life of me remember who it is. Also seen them on ebay.
    Sent from my SM-G930T using H.A.M.B. mobile app
  4. swifty
    swifty
    Apparently you can get them from Bob Drake as paintslinger 805 on here has a set and he was comparing them with originals in his thread about the recreation of his Grampas roadster. Now he's got originals he is selling the Drake ones as they're not as good and going to use the OG's
    onekoolkat1950 likes this.
  5. Mr48chev
  6. The mounts you show are 1932 V8 only. The threaded holes to use them are in the blocks for several years. (through at least '37 and probably later). I think MEC makes a reproduction,
    (330) 644-3450, modelengineeringco.com. These do not appear in their online catalog but try calling/emailing them. I have never seen their product and haven't heard anything good or bad about it. Has anyone seen them? Note that the ones you show have been modified to clear the fan belt when using the block mounted water pumps ('37 and up). The '32 pumps mounted in the head.
    Charlie Stephens
  7. onekoolkat1950
    onekoolkat1950
    Thanks every one. I've got a 38 block going into a single seater project and the pump mounts are as wide as the frame. This style mount will solve my issue.
  8. Mr48chev
    bct and onekoolkat1950 like this.
  9. Bader2
    Bader2
    Bob drake used to make em,not sure if they still do. Not that hard to make your own,i had one used it as a template to make the other one ,3-4 hours and away you go.[​IMG]
  10. thommoina33
    thommoina33
    Alliance Member
    from australia
    Early ford store have them.
  11. onekoolkat1950
    onekoolkat1950
    [​IMG]my boy Petes hookin me up with this one. Thanks buddy
