Hot Rods Where to get gauge holes cut in SoCal?
Discussion in 'The Hokey Ass Message Board' started by JimSig, Feb 10, 2011.
  1. I know, I could do it myself with a Sawzall, but I'd like something a little more professional. Anybody know where to go in So Calif to get the two different sizes of gauge holes punched or cut? Dash is out of car.
    Thanks HAMBers.
  2. hotroddon
    hotroddon
    I just use Holes saws - get em at Sears
  3. Greezeball
    Greezeball
    Find an electrician with a hydraulic Greenlee punch.
  4. cretin
    cretin
    Sawzall?!
    Hole saws is the way to go
  5. themoose
    themoose
    Hole saw works for me.Just as clean a hole as with any other method I've seen.They are available in just about any gauge size.
  6. jcmarz
    jcmarz
    from Chino, Ca
    You can do what Hotroddon said but if you want to pay someone to do it there's Patton steel off Mission in Ontairo. They do all kinds of metal work plus they sell metal and tools.
  7. Muttley
    Muttley
    I'll bet that would look great, be sure to post some pictures when you get done. :rolleyes: :eek: :D
  8. Atwater Mike
    Atwater Mike
    Sawzall? Yer goin' round in circles! (famous song of the '60s...)
  9. burl
    burl
    from Minnesota
    Id just did mine last weekend in my bridgeport with a boring head.Really tuned out nice.Accurate and perfect holes.If you were closer i would take care of it for you.Only had a couple of hours into it from start to cleanup.
  10. greazhonkey
    greazhonkey
    There is generally enough lip on the gauges to cover the hole saw marks. In my opinion get a hole saw and do a test hole on some random piece of sheet metal and see if your gauge lip covers enough to give a clean finish. It will put you dollars ahead
  11. Nothing like fancy tools to make a 15 minute job last 2 hours!:rolleyes::D
    Holesaw or ask an Electrician pal to use his Greenlee. :)
  12. john walker
    john walker
    hole saws can chatter and gar up the surrounding metal. i drill a hole inside the scribe line and use an air saw. looks like a mini sawzall. get as close to the line as possible, then finish to the line with a file or a die grinder. die grinders can chatter too, FWIW, so hold tight.
  13. burl
    burl
    from Minnesota
    Had to move the two outside holes .110 off center so hole saw would have never worked very well.Tman i know ur just jerking my chain.
  14. dreracecar
    dreracecar
    from so-cal
    Hole saws work fine--- but replace the drill bit with a 1/4" rod to keep the drill from side cutting.
  15. 12905
    12905
    You can use chassis punches - they do a much cleaner job than hole saws.
  16. 5window
    5window
    I use a new,dedicated hole saw.Work fine for me.
    JimSig, just FYI, your avatar AAA badge is from northwest PA. The PMF in the center is for Pennsylvania Motor Federation, a forerunner of the AAA clubs.
  17. swazzie
    swazzie
    HAHAHA hole saw HAHAHA
  18. dodgerodder
    dodgerodder
    Hole saw will work very well. What I recommend when drilling thin sheet metal is to put a scrap of plywood under the dash panel as a backer. Clamp the wood backer & the dash panel together & drill away.
    It will leave a very clean hole, and will prevent the hole saw from "catching" the sheet metal & making a mess of it.
    Hope this helps a little
    Dan
  19. GREASER815
    GREASER815
    I use a hole saw or a knockout punch. My grandpa was an electrician and they used these awesome punches to cut holes in breaker boxes and such.
  20. REBEL43
    REBEL43
    from TENNESSEE
    another vote for hole saws,but buy the best you can find.
  21. roughneck424
    roughneck424
  22. Warpspeed
    Warpspeed
    Drill a ring of small holes, then join them up, and use a file to finish the job.
    Slow, but it costs nothing, you can get the hole right on size, and you won't bugger your dash. as you might if you have an accident with some kind of power tool.
  23. thunderbirdesq
    thunderbirdesq
    Haha, my thoughts exactly! "Really? Only a couple hours, huh?" Sheesh, I woulda got bored!:D
  24. Pewsplace
    Pewsplace
    Hollywood Hot Rods is your shop for accurate holes. They are in Burbank on Palm. Frantic Freds in Sunland, Precision Street Rods in Reseda....all good shops and will do the work right.
  25. newsomtravis
    newsomtravis
    from pville, ca
    5 minutes with a hole saw.......and if you don`t have a hole saw or the arbor, time to start collecting.........alot of these other answers will work fine, but som sound way too laor intensive for my lazy butt.....holesaw would be the most efficient.....
  26. 39 Ford
    39 Ford
    A hole saw with the work clamped to plywood, used on a drill press. Run it at slow speed and the hole will be nice enough to satisfy.
  27. hemi coupe
    hemi coupe
    from so-cal
    You can bring them by my shop, I could give you a hand doing it. I have all the necessary tools to do the job correctly.
    Jimmy White
  28. mkilger
    mkilger
    Jim Iam 15 miles from you in Riverside with a full sheet metal shop remember me?? lol we can give you a hand or a file 909-888-9045
  29. Bucksnort
    Bucksnort
    Billy Preston
    Agree with hole saw clamped to wood.
  30. ironpile
    ironpile
    Get a cobalt hole saw,their not expensive. Try Mcmaster-Carr.
