Technical Where to get lifter’s resurfaced
Discussion in 'The Hokey Ass Message Board' started by Olgreen65, Jan 10, 2024.
  1. Olgreen65
    Olgreen65
    Hi, I was wondering if someone could guide me where to get my lifters resurfaced in Oregon, I’m tossing a h&c sportsman into my 8ba and installing adjustable lifters, my options are adj iskys or Johnson’s.
    Sharpone likes this.
  2. Mr48chev
  3. Hillbilly Werewolf
    Hillbilly Werewolf
    I belive Oregon camshaft also resurfaces lifters, i have used them and Delta for cams, and have been happy with both.
    https://oregoncamshaft.com
  4. lake_harley
    lake_harley
    I just sent a cam for a regrind and and set of lifters for re-facing off to Oregon Cam Grinding or a 153 Chevy II engine. Don't know the results yet but will say Ken was easy to talk with and very helpful on the phone. I'm hoping for good results.
    Lynn
  5. 73RR
    73RR
    Rocker Arms Unlimited, Redding CA. 530.242.1316
  6. bobss396
    bobss396
    Where to get lifters resurfaced? On the end that rides on the cam.... I will see myself out... :D:D:D
    Jacksmith, Sharpone, 2Blue2 and 6 others like this.
  7. KenC
    KenC
    Most old school motor rebuilders will be able to do that, the big guys that sold short and long blocks to shops and dealers. I have had some done that way. Lots of 'rebuilt' short blocks got reground stock cams and lifters in lieu of new ones, along with reground cranks. Only thing actually new were timing sets, pistons, rings and bearings.
    Sharpone and Desoto291Hemi like this.
  8. 1biggun
    1biggun
    Interested on how that works out for you .
  9. lake_harley
    lake_harley
    I certainly don't expect any issues with re-faced or re-ground cam and lifters. The same parts were ground and finished during original manufacture so I don't see why it would present an issue giving the parts a new face. Oregon cam said that they feel the "old" materials are (in their opinion) of better quality than that used for current manufactured parts.
    Lynn
  10. Beanscoot
    Beanscoot
    In Canada, I've had them resurfaced at Shadbolt Cams in Vancouver, B.C.
    I guess success depends on the lifters being through hardened (which I think almost all are) vs. being only surface hardened.
    GlassThamesDoug and Sharpone like this.
  11. Tetanus
    Tetanus
    I think pete1 here on hamb does them
  12. Do any of you guys know, if these places put the crown on the lifters, or just make them flat? Gene.
  13. I would hope they finish them with a crown. That’s what makes them rotate.
  14. RmK57
    RmK57
    I had Shadbolt cams resurface my Johnson solids a little over a year ago. New cam broke in great. It’s under new management but the fellow I spoke with and performed the work seemed to be on the ball.
  15. Yep, that and the correct taper on the lobes. I had some mushroom lifters done a while back. The guy just made them flat... not happy. Gene.
    Sharpone and Truckdoctor Andy like this.
  16. alanp561
    alanp561
    Talk to @chicken. That's what he does:)
  17. 19Fordy
    19Fordy
    Should the Johnson Adjustable lifters for a Ford Flathead be "radius" ground or flat.
    This post got me thinking so I thought I'd ask.
  18. saltracer219
    saltracer219
    All flat tappet lifters have a crown ground into the surface otherwise they will not rotate. It takes special radius grinding equipment to do this correctly, don't let anyone tell you otherwise! Call Oregon Cam and talk to Ken, he has been doing this for over 40 years.
    Chavezk21 and Desoto291Hemi like this.
  19. Lol,,,,I guess some people take the term flat tappet literally !
    Salt racer is right,,,,,,
    Yes,,,,they must have a radius on the face to contact the lobe or they will wear badly .
    Kind of like your road beds,,,,,they have a crown in them also,,,,otherwise the water won’t shed correctly .
    Tommy
    warbird1 likes this.
  20. Fortunateson
    Fortunateson
    I had my cam reground by them and Johnson’s solids resurfaced at the same time.
    I know that the previous owner p***ed away last spring. I hope that they are still in business...
    There is another operation up in Armstrong, BC I believe.
  21. Pete1
    Pete1
    from Wa.
    Can people show pics of lifters that various shops have done?
  22. 57 Fargo
    57 Fargo
    Interior cam in Salmon Arm, I spoke with Jim there last week about my Hemi cam.
  23. keith adams
    keith adams
    Some lifters ride off center on the cam lobe making them turn.
    Desoto291Hemi likes this.
  24. Sharpone
    Sharpone
    Schneider Racing cams resurfaces lifters, I had a cam reground by Schneider and am very pleased, I did have new lifters (Isky) so didn’t have old lifters resurfaced. I believe prices start at $5.00 per lifter. I have some used factory Sbc lifters and if I ever build another Sbc I’ll send these lifters to Schneider to be resurfaced.
    Dan
  25. dart4forte
    dart4forte
    from Mesa, AZ
    I had several sets of lifters done by Oregon cam. I think 73RR has a machine shop local to hem that does lifters.
  26. 19Fordy
    19Fordy
    THANK YOU all for replying to my flathead lifter grinding question.
    Makes sense.
  27. PackardV8
    PackardV8
    We regrind lifters for engines we build, mainly Studebaker, Y-block, ***mins, 235"s, et al. Don't really need any more job work, but if you can't find anyone to do them for you, PM me. And yes, $5 each is the going rate.
    jack vines
  28. ekimneirbo
    ekimneirbo
    from Brooks Ky
    Anybody ever heard of a coating called Anealon? A company named Mach Development in Maricopa Az and Tech Line Coatings in Murrieta Ca apparently have a ceramic coating that is 100% effective in preventing cam failure. This is from an old magazine . Apparently its not cheap, so I would think that most people would simply put that money toward a roller cam setup.............but then it occurred to me that some engines are difficult to impossible to get roller cams for. Supposedly this treatment does NOT require normal break in or light duty springs for break in.........just start the engine and its good to go .............(Thats what the magazine says):)
  29. Beanscoot
    Beanscoot
    PackardV8, do you know if pretty much all lifters are regrindable (i.e. through hardened), and know of any exceptions?
  30. Taboo56Chevy
    Taboo56Chevy
    I can vouch for Oregon Cam Grinders as well. Have had them do a few 348 Chevy cam and lifters and they were flawless. No issues and lots of miles on them.
