Where to get Model A wishbone ends
Discussion in 'The Hokey Ass Message Board' started by jettwein, Jan 12, 2006.
  1. jettwein
    jettwein
    A while back, I bought a really cool set of split bones from Killer and they have these funky pocket-type ends on them where they were split. There's a spring inside with a little hemispherical piece that helps to sandwich the ball/male end of the system that is welded to the frame rail between it and the other side, which is a threaded piece in the end of the bone.
    Anyhow, I lost one of the little hemisperical pieces when I was getting a spring perch out of it... wondering where to get one and what the hell they are called. I'm sure there's a name for them other than "little hemispherical pieces". :)
  2. Andy
    Andy
    I think what you have is the stock parts of a Model A tie rod/drag link. Any old Ford supplier should be able to fix you up. These same parts were used for decades on all sorts of front ends. I think Chevy used them into the '50's. Look in a yard.
  3. jonski und29
    jonski und29
    check out nwspeedequipment.com. they not only have the ends, but also mounting tabs to the frame.
  4. jettwein
    jettwein
    Thanks everyone... this is why the HAMB rules.
