Where to get rubber plugs?
Discussion in 'The Hokey Ass Message Board' started by midnightrider78, Jan 14, 2012.
  1. midnightrider78
    midnightrider78
    I'm looking for a couple rubber plugs to fit 1.375 holes(Access holes for body mount bolts). The car did not have plugs in these holes originally, but I'm trying to close them up so mice can't get inside the floor brace. I've checked Arnold Motor, Lowes, Shoppers Supply, J.C. Whitney and a few others and have come up empty handed. I've found a pair on Ebay, but they are "NOS Datsun" and the guy thinks that makes them gold or something. What now? Any help would be greatly appreciated.
    Thanks
    J
  2. Tin foil in the hole will keep the mice away until you locate the plugs.
    Check Chevy van hinge bolt access hole plugs. Seem close to that from memory.
  3. AZbent
    AZbent
    Foil tape would be better, it could even be permanent.
  4. AZbent
    AZbent
    In the aviation industry it is called speed tape. The heating and air conditioning guys use it to seal the seams on the ducts.
  5. MT26
    MT26
    Try Steele Rubber Products: www.steelerubber.com they have almost anything you would want pertaining to rubber products.
  6. jcmarz
    jcmarz
    from Chino, Ca
    you can try the Adult Toy store. Plenty of rubber plugs.
  7. Davyj
    Davyj
    Try Spaenaur, they show some in their on line catalog
  8. Tin foil keeps mice out of holes because they dont like the noises and especially the rough edges of crumpled up Tin foil.
  9. badshifter
    badshifter
    Use dynamat. Cut to size.
  10. midnightrider78
    midnightrider78
  11. brad chevy
    brad chevy
    Why not go to the local hardware store or parts house and get the rubber freeze plugs with the bolt in the center. Install and take out when you need too. They are about an inch thick,rat will be to full to eat after all that eating.They come in 3/4 inch up to 2 1/2 inches
  12. carsnbikes
    carsnbikes
