Hot Rods Where to get this trim clip?
Discussion in 'The Hokey Ass Message Board' started by junkyard junky, Mar 5, 2015.
  1. junkyard junky
    junkyard junky
    I need four trim clips for the small molding on my 64 Catalina 4dr. The clip has to be a push in because I can't get behind it from the inside. Measures 1.5 inches wide and .4 inch tall at the center. Does anyone know who makes these or is there something close that I can modify?
  2. 40StudeDude
    40StudeDude
    Try Au-Ve-Co...they make a lot of clips...available at most upholstery supply places...
    R-
  3. My 56 Chevy had similar trim clips. Try a tri-five Chevy supplier. Looks like the 210 trim around the window clips.
    40fordtudor likes this.
  4. Restoration Specialties may have them. McMaster-Carr also may have them.
  5. xhotrodder
    xhotrodder
    If all else fails try Ebay.
  6. 51 BIRD
    51 BIRD
  7. 54fierro
    54fierro
    from san diego
    google push in moulding clips see if you can modify anything to work for you.
    universal push-in clip
  8. Try your local body shop, they usually stock about a million different clips....
  9. spooler41
    spooler41
    Stud-dude has the answer your looking for, Au-Ve-Co .com
    they have the largest selection of clips and fasteners I've ever seen.
    ........................ Jack
  10. rdscotty
    rdscotty
    from red deer
    X3 on Au-Ve-Co
    Find the oldest body shop supply business in your area. They may have stuff in the back that's been there forever. Restoration shops too.
    As mentioned before you may have to think outside the box and modify something to fit or combine two clips. You could put a barrel clip in the hole and then put a different clip in the mld. or even make one out of sheetmetal and a serrated nail. Or put a plastic trim clip thru a hand formed piece and insert in mld.
    You could just put a flat piece in the mld and use two sided tape
    You say you have no access to backside, but is it in a area where you could drill access holes with a hole saw to gain access?
  11. stanlow69
    stanlow69
    Send me a PM. I have five I can send you.
  12. fordor41
    fordor41
    try an auto paint store. My local one has a whole wall of trim clips
  13. chevy57dude
    chevy57dude
    1. Maryland HAMBers
    Junkyard Junky - They look very close to the beltline trim clips on the tri 5 210 series. Last week I installed this trim on my car. Got a few extra ones around. PM me if you need 'em
  14. B.A.KING
    B.A.KING
    Its a GM product, so I would try Ecklers, Late Great Chevy. 58-64 Impalas. I think they even carry later model impalas Also in a different catalog
  15. 37 caddy
    37 caddy
    from PEI Canada
    If you only need 3,you could remove 1 from each other peice of trim and make it work that way,i have done this in a pinch,the other peices wont miss 1 clip each?.Do you have a pick and pull in your area,they should have something on another type of car that might work?. Harvey
  16. Blue One
    Blue One
    from Alberta
  17. junkyard junky
    junkyard junky
    Sent a couple of pm's. Looking for a picture of the 210 clip.
