Where to get wide whites
Discussion in 'The Hokey Ass Message Board' started by impalamike, Feb 25, 2007.
  1. impalamike
    impalamike
    from Texas
    Can you fellows recommend a good place to get 15" wide whites (2")? Thanks, Mike
  2. houseofhotrods
    houseofhotrods
    Coker tire rocks, I use them all the time. I usually just contact the company direct, but you can use distributors closer to you. Their website is www.cokertire.com . The tires are awesome - they do radials and crossplies as well. Hope this helps. Tim :)
  3. hsheartaches
    hsheartaches
    Is the search function still down?? Yeah, Coker would be the place to get yo tires. WWW's are a little more pricey that you're standard 4 for $99 at discount tire. :D
  4. chaddilac
    chaddilac
  5. LasVegasDirtyBird
    LasVegasDirtyBird
    from las vegas
    you can do the 4 for $99 at discount and buff them out. your white will be wider than 2 inches though. practice on 2 garbage tires first. a DA sander or a drill with a sander wheel thing(dont know what to call it) will work the best, use 80grit then 220 to make it ***y
  6. chaddilac
    chaddilac
    Or you can make one of Texas finest swap meets and pick em up from Wallace Wade Tires....
  7. Frank
    Frank
    What is the going price typically for bias-ply? I got a quote on a set of wide whitewalls, 6.50 16's and 7.50 16's with tubes for $650. I thought that was a bit steep.
  8. chaddilac
    chaddilac
    I think I paid $560 total for mine from Wallace Wade tires... I got 5.50/7.50 16's with tubes. I picked em up in texas at a swap meet and saved the taxes and shipping.
