I need to glue in the rear side woindows on my car, and I am not sure where to get the good window glue. And Ideas? The local parts store (Kragen, Pep Boys) doesnt have it.
The local gl*** shop had some good stuff for windshields that sets up fast. $12 for the tube out the door.
I'm a gl*** guy, You pay for shipping i'll send some to ya I'll give you the right primer to, shot me a P.M Chris
WORST POSSIBLE THING TO DO!!!! JEEZE!!! What you need is "Windshield Urethane". It comes in a caulking tube & is used to glue in windshields. Should be available at any autobody supply & I would be surprised if some auto parts didn't have it. While you're at it, find & caulk everything around the house that needs it: once open you can't save the rest of the tube. Also make sure to read the instructions & get the right solvent for cleanup. It will make a large mess. ~ Paul aka "Tha Driver" Since I gave up hope I feel much better.
napa, has alot of the time. either in black or clear. but your best bet is paint stores like finishmaster or something to that effect.
Use the gl*** guy!!! Not silicone, regular window urethane is the only way to go....clean it, prime it, install it.....forget it
auto paint places have 3m stuff, santa ana or orange would be close. you can try betz in orange or if your down south you can try the paint store in laguna niguel.
The window urethane are moisture cured, that is why you need to use it all once the tube is opened, it will cure in the tube. You do not have to put water on it, it will cure fast enough with moisture in the air.
stick with windsheild urethane i could also get you a tube and some primer you would only have to pay for shipping the stuff i use is under the brand name "Betaseal" and it works really well
you poor *******!! your a gl*** guy too! do you own the shop? i cant wait to get a little busier with the rod and custom work so can wash my hands of this miserable biz for the rest of my life! insurance co's ****!! sorry guys its like having turrets , i just see the words "auto gl***" and i blurt that **** out. yes as they said get a tube of urothane..dont use to much, or it will be up your nose before you know it
I purchase stuff at this place http://www.autotoolmart.com/cgi-bin...2563&mmtmt=5&gclid=CObJ-NbrtIMCFTpyLAod11DeFg they happen to have a place in So. Calif. SunValley. but call for a free catalog and they do have 3m window adhesive about $10 a tube I bought some and it sticks and sticks to everything near it you the car and etc. Ed ke6bnl
