Hot Rods Where to mount a generator on a Flathead
Discussion in 'The Hokey Ass Message Board' started by drumyn29, Mar 11, 2026 at 12:51 AM.
  1. drumyn29
    drumyn29
    I know Willy's and Hemi's, I don't know Flatheads. My young neighbor bought his first hot rod and he's asking me for help. We need to install the dual carb set up but it looks like the generator will rest right where the coolant hose is. Can I get any advice on this job before I start. I'm not sure what to do about the roof belt line.
    IMG_1612.jpeg IMG_1619.jpeg IMG_1610.jpeg Screenshot 2026-03-10 at 10.48.00 PM.png IMG_3776 2 2.jpeg IMG_7111.jpeg IMG_0480.jpeg
  2. AVater
    AVater
    Wow, looks like you have a hemi problem there. Im sure many would be happy to help:rolleyes:
    With regards to your question, if you zoom in on the photo you can see I used a certain Gates hose to solve the problem. I can look up and share the part number later today.
    Hope this helps.
  3. lostn51
    lostn51
    from Tennessee
    I’d like to know the part number because I’m running 2 dueces and ac. I was just going to fab a set of hoses up using stainless tubing but I’d rather have all rubber hoses
  4. Petejoe
    Petejoe
    from Zoar, Ohio
    I used an exhaust pipe bender and formed a shape that allowed two small radiator hoses to connect it IMG_1778.jpeg
    Algoma56 and AVater like this.
  5. The generator may just clear the front carb, but if needed you can flip the water outlet so it points out towards the side and change the hose so it will clear the offset bracket. I would see if the generator can still be installed at the 12 o’clock position so you maintain good belt contact with the water pump pulley, with the offset mount the belt can slip a little bit at higher rpm. See if the generator clears the front carb by mocking it all up on the bench before tearing everything apart.
    AVater likes this.
  6. AVater
    AVater
    Quick update: The hose I used on the right (generator side) was Gates 21205. The driver side hose is 20137.
    Algoma56, lostn51 and AccurateMike like this.
  7. drumyn29
    drumyn29
    thank you
