where to mount bags on a Galaxie wagon?
Discussion in 'The Hokey Ass Message Board' started by Odd Rodney, Dec 27, 2009.
  1. Odd Rodney
    Odd Rodney
    Ok nice short and sweet.
    Im reworking a "HACK" job done on my 64 Galaxie wagon. It has full air ride susspension but the lack of craftsmenship was unsafe and ugly so I have taken it upon myself to rework the system and the setup.
    The rear of the car already had a triangulated 4 link but the welds were shotty so a new one is being put in...by me.
    The former bag setup had the rear bags mounted to the 4 link in front of the rear wheel...to the frame.
    I would like to mount the bags to the axle but Im wondering if the ride quality will suffer.
    anyone who can offer a suggestion as to where the rear bags should be mounted for maximum lift and ride quality would be appreciated.
    Thank you in advance for your help.
    Rodney
  2. FrozenMerc
    FrozenMerc
    Rodney,
    Here is a pic of were I mounted the bags on my '62 Monterey Wagon (same ch***is as your '64 Galaxie). I don't have the car on the road yet, so I can't tell you how it rides. Hopefully it will give you some ideas, though.
  3. fakesnake.com
    fakesnake.com
    I think those bags should be behind the rear axle. Here's a couple of shots for you on different options. The first shot is a 61 Ford wagon and the second shot is a 62 Mercury (2 door convert).
  4. Lone Star Mopar
    Lone Star Mopar
    Just curios, why behind the axle instead of the front ?
  5. Reds 29
    Reds 29
    Generally speaking bags mounted behind the axle will give a softer ride. Bags mounted in front of the axle will give you more lift. It is still dependent on size, how they are mounted etc.
    Red
  6. fakesnake.com
    fakesnake.com
    I am by no means an expert but you are limited on space in front if you run shocks. Plus, if it is triangulated 4 link that gives you even less room.
  7. AnimalAin
    AnimalAin
    It seems to me that running the bag between the frame and axle ensures that the fully compressed height is a little higher than if the bag is mounted fore or aft of the axle, which would allow the axle to go all the way up to the bumpstop (you do run bumpstops, right?). It isn't probably a big deal at running height, but one of the main draws of the air suspension is being able to park it with the ch***is LOW isn't it?
  8. cracker head
    cracker head
    Got anymore pics of your setup?
  9. MengesTwinCustoms
    MengesTwinCustoms
    as long as the suspension moves freely, i wouldnt think the location of the bags would affect the ride that much. my 51 ford was ontop of the rear end to the top of the c notch, and my 47 buick is infront of the rear end on the link to the frame and both ride the same. I have knee shocks on the buick and it was really easy to mount them because they don't take up very much room at all. I would suggest shocks, especially in front.
  10. FrozenMerc
    FrozenMerc
    Cracker,
    Check my album, there are a bunch of pictures of the ch***is.
  11. lgh1157
    lgh1157
    Here is my 64, cut out the O.G crossmember and welded one right in front of it so i could run longer upper bars . . . . :
    Bags behind because of space, but i might do a new set up like faksnakes, but i will run the lower bars with bags on em and keep my upper bars the same :
  12. ryno
    ryno
    id run the bags on the lower link bars in front of the axle.
    way less pressure will be needed to lift the car, thus creating a softer ride.it will also lift alot higher, think change flat tires.
    with doing a set this way you wont need as much trunk space for a upper bag mount/xmember also.
  13. lgh1157
    lgh1157
    Frozen Merc - are your links level at ride height ?
    Depending on where the bags are located on the bars it would take more pressure. . . . . . way more pressure
  14. brewsir
    brewsir
    I would think that running the bags in front of the axle would require more pressure to lift the car as the bar is essentially a lever...a longer lever will need less muscle to get the same effect as a short lever.
  15. FrozenMerc
    FrozenMerc
    Yes, The lower links are level at ride height. The picture was taken from above with the frame sitting on the bump stops, so it is not the best.
  16. nowaxn5
    nowaxn5
    How low are you guys getting with these setups?
  17. FrozenMerc
    FrozenMerc
    Mine sits on the orginal bump stops with no air pressure. I didn't feel there was any reason to c-notch the frame and go any lower.
  18. fakesnake.com
    fakesnake.com
    Here's how low mine will go. Any lower and my rack and or oil pan would be touching the ground. Sorry about the larger pic.
  19. lgh1157
    lgh1157
    I sit on the frame with no notch
    L
  20. southern iron
    southern iron
    bring it to me i'll fix it for ya
  21. jscoma47
    jscoma47
    This is the way I run'em on my truck... it rides real nice and took up the space where the coils where. Above the axle is a very common placement. I look at it this way... if you can mount the bags as close to the way stock coils would be you are going to get the best ride.... thats what the engineers are paid to figure out at the factory.
