Where's the VIN, '52 Ford F1
Discussion in 'The Hokey Ass Message Board' started by Bob 1743, Aug 2, 2011.
  1. Bob 1743
    Bob 1743
    Where is the VIN number (ID number ) on a 1952 Ford F1 pickup. ?
  2. gdub
    gdub
    Top of the p***enger side frame rail just behind the motor mounts.
  3. Mudslinger
    Mudslinger
    Also in the glove box there should be a plate on the lid.
  4. SMOKINFLATHEAD
    SMOKINFLATHEAD
    from SOCAL
    should be a plate on the fire wall in the engine bay p***enger side.
  5. twink
    twink
    My 52 has a metal plate inside the glove box with the VIN, Not sure if they were all like this or not.
  6. LowKat
    LowKat
    Here's where they are on my 51 F1.
    Driver side stamped in the firewall (this isn't VIN but plant ***embly info).
    P***enger side is a rivited tag on the firewall.
    Frame stamped. (the location could be slightly foward of where I indicated)
    Tag on the glovebox lid.
  7. HOT40ROD
    HOT40ROD
    from Easton, Pa
    What LowKat said. I have found the frame stamp on the right frame rail as far forward as the front cross member.
  8. Atwater Mike
    Atwater Mike
    Lowkat said to look to the right framerail...my '52 had been cleaned up nicely, ch***is painted with a nice black enamel. Look as I did, I couldn't find it...
    Suddenly, it jumped right out at me, right behind the crossmember, p***enger sidetop of frame rail. Oh, and the VIN tag is screwed onto the back side of the glove box door.
    Screwed, not riveted. Henry did them like this.
    Thanks, Lowkat.
  9. LowKat
    LowKat
    One of my 48's is stamped on the p***enger side and the other 48 F1 is on the driver's side. I believe the frame is supposed to be stamped in 3 places on the same frame rail but I've never looked.
  10. Mudslinger
    Mudslinger
    In 52 the tag on the firewall was dropped and put in the glove box for some reason.
