Technical WHERES THOSE PAINT GUYS???
Discussion in 'The Hokey Ass Message Board' started by Old GW, May 25, 2017.
  1. Old GW
    Old GW
    IS IT ENAMEL OVER LACQUER, OR LACQUER OVER ENAMEL????
    I HAVE THIS CRS DISEASE.
  2. tfeverfred
    tfeverfred
    I've read they don't mix at all, but I'm sure an expert will chime in soon.
  3. tfeverfred
    tfeverfred
    From Duplicolors website:
    Can Enamels be used over lacquers?
    Yes. Dupli-Color® enamels can be sprayed over lacquer substrates, or any other painted surface that has been sanded smooth and clean of dirt, grease, and dust.
    Can Lacquers be used over enamels?
    Lacquers have a tendency to lift enamel surfaces. Lacquers will work over most fully cured enamels that have good film integrity. Test carefully in an incon****uous area before proceeding.
  4. BJR
    BJR
    Enamel over lacquer, if you do it the other way it will lift and wrinkle.
  5. Flat Six Fix
    Flat Six Fix
    Yup, exactly, plenty of synthetic and acrylic enamel shot over lacquer and lacquer primers in the old days.
    You probably could shoot Lacquer over enamel, if an 2k epoxy sealer was sprayed over the enamel substrate first.....
  6. Bandit Billy
    Bandit Billy
    I remember it this way- liquor before beer, always be clear. It applies to lacquer before enamel too.
    loudbang and slimcat7m3 like this.
  7. millersgarage
    millersgarage
    but... thin your enamel with lacquer thinner and it will flow out great
  8. Paint Guru
    Paint Guru
    from Bowdon, GA
    If your enamel does not have a hardener, it doesn't matter, both can have the same affect. The solvent in your new topcoat will soften the paint underneath. This is what causes wrinkles. We developed a product called "wrinkle free" that is a low solids film that acts as a adhesion promoter. It has non aggressive solvents in it, that will create a barrier if you think it might wrinkle.
    I just sprayed test panels this past week, enamel over lacquer and lacquer over enamel, with no issues using the wrinkle free. However the film did soften a little at first, but no issues with lift, durability or gloss.
    Sent from my SM-N920V using The H.A.M.B. mobile app
