Which Auto Darkening Welding Helmet?
Discussion in 'The Hokey Ass Message Board' started by Scott, Jul 26, 2006.
  1. Scott
    Scott
    What helmet would you guys suggest and why for mig welding etc.
    Thanks
  2. 52pickup
    52pickup
    from Tucson, Az
    I love my Miller helmet. Its their middle priced one. I am going to buy another here pretty soon so I can have an auto I can leave at home. Going to get either millers top line, or a speedglas, both are very nice helmets.
    if your just going to be welding occasionally the mid line miller is a good one.
  3. What I recommend is that you get one with the backup replaceable battery whatever you do.
  4. Deadbird
    Deadbird
    I like my Speedglas helmet. It's comfortable and lightweight.
  5. headhunter
    headhunter
    from Austin, TX
    I have a Miller Elite series - the auto darkening one with the large window - and I love it. Before I got this I was borrowing a Jackson that seemed to be OK but not as well made as the Miller and *much* heavier. I ended up getting it at CyberWeld which had the best prices when I shopped around:
    http://store.cyberweld.com/autdarwelhel.html
  6. Squablow
    Squablow
    I bought a really expensive Speedglas when they were first coming out, it's an excellent unit even 5 years later. I use it so much, i have a hard time welding without it.
    I was in a welding store last week and I tried on one of those big window Millers and they are really nice too. Light weight and when they're on the view is so clear and bright, plus the new ones have 5 shade for cutting with a torch, I was impressed with those.
    So I guess either a big window Miller or a Speedglas would be my choice, and seems to be everyone else's choices too. DON'T buy one of those cheapie **** ones from Harbor Freight, they'll work for a while but they break if you drop them. My Speedglas has been all beat to hell and still works good.
  7. arkracing
    arkracing
    I have Miller Big Window Elite (it improves you visibilty greatly if you wear gl***es)
    Love it. When I got it a couple years ago it was $280 and well worth it.
    It's much lighter than the Jacksons & Speedgl***
    Battery power as well
    & it has 4 sensors - helpful for low voltage welding (i.e. TIG)
  8. flatheadhero
    flatheadhero
    I have a Big Window Elite Miller too. It is great, love it. 221.00 new off ebay.
    http://cgi.ebay.com/MILLER-ELITE-AUTO-WELDING-HELMET-BLACK-216322_W0QQitemZ130008975730QQihZ003QQcategoryZ92090QQrdZ1QQcmdZViewItem
  9. Killer
    Killer
  10. rumblytruck
    rumblytruck
    Lemme stir everybody up. What about these el cheapo Harbor Freight
    $50 auto darkening helmets? It ain't me but I got a buddy that uses one.
  11. 1FATGMC
    1FATGMC
    from SE Utah
    I'll admit to using one. The current one I've used for the past couple years with no problems and it has two delay settings and various shade settings. It was about $60. I can also see out of it with my bifocals.
    The one I had before that one also came from them and I used it for a number of years before it went belly up. I did quite a bit of research on the net and found there are only a couple different companies actually making these and others are putting their names on them. The previous one was also sold by Hobart and I believe Miller.
    The one I have now is sold under a couple different names. If I welded for a living I'm sure I would get one that the other guys are mentioning, but for me I'm real happy with the one I have and have other friends that have ones from HF and that are happy. These helmets have come a long ways in the last 10 years and I would say the cheapest one you can buy today is probably better (faster reaction time) than the most expensive one from 10 years ago.
    Let the flaming begin;) .
    c ya, Sum
  12. mercury Bill
    mercury Bill
    The only problem with the hf one is the weight, my pops has one but he dosent weld that much anymore. I have a miller/hobart hood I really like it.
  13. I have a Jackson and although it probably weighs twice what a Speedgl*** does I'd rather have the Jackson because I can put it all the way back to verticle on my head so I don't "feel" the weight. The Speedgl***' I've used sit horizontal on your head and the end up hurting your neck way more than a Jackson.
  14. Scott
    Scott
    Thanks Fellas:D
  15. Scott
    Scott
    Just ordered Miller elite from cyberworld
    :cool:
  16. Thorkle Rod
    Thorkle Rod
    I like my Harbor frieght it works but again I only were wear for an hour at most at one time.
  17. arkracing
    arkracing
    Let us know how you like it!!! :)
    Edit: Uhh the Helmet!
  18. Optrel Rules.
  19. OLDSKEWL61
    OLDSKEWL61
    i bought a lincon when they first came out changed my life. not to adj. just 10 or 11 shade ill keep watching this post though mine got broke while moving to new house!
  20. kyle paul
    kyle paul
    from sac
    what ever one you get make sure it has atleast a shade 11 lens /.kyle
  21. Blownolds
    Blownolds
    from So Cal
    I've always been leery of those. What with light travelling 186,000 miles per second, I have to believe that your eyes (about 16-24 inches away) still receive a bit of flash before the lens darkens, evertime the arc is struck. I have no data to back up my su****ion, but just by using common sense, I would recommend the auto-darkening helmets only for those occasions that a normal helmet just won't work.
  22. K13
    K13
    The biggest thing is to make sure if it is a cheap one that it has ANSI Z87.1 certification. This means that the helmet will block out the damaging rays IR and UV even when they are not darkened. The darkening is more for the brightness of the arc which is very uncomfotable.
  23. MIKE-3137
    MIKE-3137
    It would be interesting to do the math, Miller claims a 1/20,000th of a second response time for the lens to darken.
  24. Avg.Joe
    Avg.Joe
    I also had a hard time trusting my miller auto after 15 years of conventional helmet use. My biggest problem is at night at work no matter where the sinsetivity adjustment is it will auto darken from the sparks from a hand grinder, then for a moment you can't see what the hell you are doing. It will also auto darken when outside at night and you look toward an area light or light pole.
    Joe
  25. bcarlson
    bcarlson
    I got the plain black Hobart XTV model for about $135. I love it. I use it strictly for MIG though. I tried it with a stick welder, but the spatter is so bad I'm worried about ruining the sensors. Also, I dropped it hard on the concrete once so far with no problems. :rolleyes:
    Ben
  26. XSCOOTERX
    XSCOOTERX
    from Brier,Wa.
    I only have one thing to say.....You get one set of eye's...If yours are only worth 50.00 ..then have at it ....:eek:
  27. 52plybizcoupe
    52plybizcoupe
    from Brier Wa.
    miller the bad boy one big window 4 sensor becaus i had a cheep harbour freight one but when i found out i liked to tig weld not sensitive enough
    i have a magnifier in mine now so when i tig my tungtstin looks like a freeking 44mag sharpie
  28. MIKE-3137
    MIKE-3137
    I'm going to check into that magnifier thing, thats my biggest problem trying to tig is seeing the stupid puddle, I'm gonna break down and get the Elite too.
  29. Scott
    Scott
    I have a problem focusing in on the puddle also!
  30. Seeing is everything, if you have an excellent helmet and keep the lenses changed you'll be a better welder, and you'll -get- better faster because you can see & understand. The best welder in the world can't weld for **** if he can't see what he's doing. Bad helmets only lead to frustration. You'll never learn to be good at small/thin TIG without clear vision.
