Which battery to use ?
Discussion in 'The Hokey Ass Message Board' started by Frenchy Dehoux, Sep 2, 2009.
  1. Frenchy Dehoux
    Frenchy Dehoux
    I would like to get everyone feedback on which is the best battery on the market to buy. This one will be placed in the trunk of my 32 and would also like to have it in an amo box. Any help and suggestions are appreciated.
    Thanks
    Frenchy
  2. 29SX276
    29SX276
    I've had good luck with the red top Optima battery;been using it for two years now(so far).I have one electric wiper,electric fuel pump,gauges and lights.
  3. Fuzzy Knight
    Fuzzy Knight
    from Santee, Ca
    Frenchy
    Which ever battery you chose I don't think I would put it in a Metal ammo box
  4. twofosho
    twofosho
    Optima batteries haven't had the best reputation of late, so I would probably find something else. I personally have had great luck with house brand batteries from Costco. Used to be made by Johnson Controls. Excellent warranty thats honored no questions asked. Good bang for the buck.
    Whatever battery you choose should be fine in an ammo case if you take precautions to tie it down properly and vent it. The metal of the case should help it shed heat. Nothing wrong with a few well placed louvers for venting it either, if it's not placed inside the p***enger compartment.
  5. crackerass54
    crackerass54
    from dallas
    I've never had any problems with optima batterys and have put them through some ****. You can put any battery in that ammo box just make sure it is not sealed completly(vent), I would just say make sure you have room to service your battery in that box. I like the louver idea too.
  6. motorhead711
    motorhead711
    Optimas are good, little pricey, but well worth the money.
  7. What ever brand you use make sure it is a gel battery. Liquid acid batteries don,t do well enclosed! The vapors will eventually cause corrosion of any close metal parts. I had to switch up because the marine battery case in my trunk was bolted through the trunk pan and the bolts and washers looked like chia pets with all the corrosion going on.....
  8. 5window
    5window
    Totally agree with the recommendations for a gel battery if enclosed and venting. Batteries are nasty little things.
    On the other hand, I have had excellent results from Walmartl batteries. Yeah, I know, I hate shopping there and would love to have better choices-but their batteries are a fair price, seem to be well made, exchanged without a h***le, hold up, most of the time, really well and look like a battery should (black).
    What more do you want? And my battery is under the car, up near the frame rail and in front of the rear axle,so I don't enjoy changing it. If your battery will not be readily accessible, I'd strongly recommend a set of remote jumper posts. Ron Francis and others sell these.
  9. 19-c
    19-c
    Walmart $59.95 had one in my truck for 6 years now no probs
  10. chop&drop
    chop&drop
    I'm running an Optima Red Top. Had it about 2 years with no problems. I wanted a gel because it's inside the car (battery box behind the back seat).
  11. Toast
    Toast
    from Jenks, OK
    Its a freakin battery folks, use your money for cool stuff and buy the cheapest battery you can find that has a warranty! Just my .02
  12. zman
    zman
    from Garner, NC
    Johnson Controls makes DieHard, Duralast, Interstate, ProStart, and Everstart as well as Optima...
  13. denis4x4
    denis4x4
    from Colorado
    I put a Red Top in my Jeep in June and it lasted less than a month. Hensley Batteries replaced it with a house brand made in the USA and informed me that Optimas made in Mexico in the past year have presented problems. I have at least five Optimas that were made in the USA that have worked fine.
  14. revkev6
    revkev6
    from ma
    I used the heavy duty bright *** yellow battery they sell at walmart for the flatty in my roadster. they were out of stock on anything else that fit. cost around $75 and has worked well for the last few years.
    my uncle has been thru two optima gel cells in his rocket powered roadster. they're junk IMO
  15. onlychevrolets
    onlychevrolets
    My brother worked for Advance Auto Parts for eight years, he wouldn't sell an Optima battery if he could get out of it, he said he was tired of replacing them within a year.
  16. hotrodladycrusr
    hotrodladycrusr
    I have had no lucky with Optima batteries. Pulled TWO out of Big Olds this summer and replaced with one from O'Reilys. No issues what so ever now. Optima rep at the GG Columbus event lied right to my face. Won't use another Optima battery in any of my cars ever. A number of my vendor pals have stopped carry them as well. Just too many issues and h***les with replacements.
  17. Von Rigg Fink
    Von Rigg Fink
    from Garage
    Ive run Optima batteries in a few of my O/T rides..nothing but an expensive PITA..
    you can say all you want about them if you love them...but im done being F-ed by Optima..wouldnt use one if they sent it to me free..:mad: all of the ones i had ****ped out when i needed them the most...and one of them they screwed with me until the warrenty was 1 day over the limit..the others died within months of them being out of warrenty..
    But i do own a boat and need an anchor:eek:
    I get mine at Car Quest..normal lead acid..work great and they stand behind their warrenty
    glad i havent had to even deal with that end of it..yet, they are still going ..one of them so far 5 years
  18. Lizard
    Lizard
    from Benson Az
    Odyssey batteries are a dry cell which means no nasty stuff to leak out or vent.
    Had one in my truck and old airplane for 5 years each, so far so good.
    Dale
  19. Frenchy32
    Frenchy32
    from arizona
    Thank You for everyone input on this interesting subject.
    Frenchy
  20. DD COOPMAN
    DD COOPMAN
    Hey Lizard, what kind of old airplane you drivin'? I love old airplanes as much as these old hotrods. Thanks...DD
  21. Terry O
    Terry O
    I recently did a pretty in-depth study on batteries and found a lot of complaints from optima owners in recent months. I finally went with a Sears Platinum I battery ($207.00) that is mounted in the rear of the Vicky. Better specs & warranty than the Optima or Exide - and Sears stores all over the country if I ever need quick service.
    Terry
  22. i usually go for cheap too. the battery in my `28 tudor is a cheap one from Napa and i just realized it is 9 years old and holding up fine. since i just said that it will now go to ****. it's mounted in a stainless steel battery box i made..and yes it is vented
    the battery in my `36 is also a cheap one from Napa . $49 3 years ago and it's mounted in a boat battery box . i think it has a 5 year warranty
