1952-59 Ford Which Electric Fan. . .
Discussion in 'Off Topic Hot Rods & Customs' started by raceron1120, May 30, 2022.
  1. raceron1120
    raceron1120
    for a '56 Fairlane? Not sure if it's been discussed here before. But I'm looking to put one in mine. Prefer a "pusher" front mount dual fan in front of the stock radiator. I looked around, there seems lots of them available but just wondering if anyone has had any experience with kits, brands etc. Thx.
  2. 40cpe
    40cpe
    from Star, MS
    From what I've read, pusher fans are more inefficient than pullers. There are many thin puller fans for limited spaces. I have a Cooling Components puller on my flathead. It is built into a shroud and the car never runs above the switch set point.
    raceron1120 likes this.
  3. jimmy six
    jimmy six
    Is there a reason for not using a stock mechanical?
  4. HOTRODPRIMER
    HOTRODPRIMER
    I was thinking the same think, stock or a bigger aftermarket metal fan? HRP
  5. evintho
    evintho
    JeffB2 likes this.
  6. jimmy six
    jimmy six
    racerron…If it’s a space problem because you swapped engines if would be nice to know before some of us make suggestions with stock or electric fans. There are many of us who fought different problems with cooling and space..
  7. fordsbyjay
    fordsbyjay
    from Lafayette
    I have a pusher in my V8 Pinto because there is no room but when you look at pusher specs non of them flow as much as a puller fan. I only use Spal, they last forever, they also make a 16" pusher that should fit.
    okiedokie likes this.
  8. raceron1120
    raceron1120
    installing the fan is preference. Thanks for the input.
    jimmy six likes this.
  9. bobss396
    bobss396
    I am using a Spal 16" in my car, a pusher and it works fine on those instances where I'm at a crawl or stopped. I bought the whole kit on eBay, a better deal than Summit had. It came with the mount kit, relay, temperature sensor, etc.
  10. JeffB2
    JeffB2
    from Phoenix,AZ
  11. mnfordfan
    mnfordfan
    Two thumbs on on Cooling Components, thin, quiet and cools my Big Block all day in 100 degree heat zero issues. (no other fan installed).
    nosford likes this.
  12. Slicks
    Slicks
    from denison tx
    Cooling Components fans used them on all my cars work great
  13. fordsbyjay
    fordsbyjay
    from Lafayette
    To add, there is several junk yard fans that could work and move a ton of air. Taurus, Contour and Lincoln Mk 8. Youtube is a great source for information on this topic.
