Technical Which freeze plug is best?
Discussion in 'The Hokey Ass Message Board' started by furyfan, Apr 8, 2014.
  1. furyfan
    furyfan
    from MA
    I know that br*** ones would not rust but I seem to recall someone saying before that steel is better and I don't remember why. Also, should some form of sealer like Permatex or similar be applied? It is for my 1972 Plymouth 318 engine. Thanks for any info.
    John
  2. d2_willys
    d2_willys
    from Kansas
  3. HOTRODPRIMER
    HOTRODPRIMER
    Br*** if you can find them,,forget the sealer. HRP
  4. GRX
    GRX
    from MD
    Some say that br*** expands at a different rate than iron so are more likely to pop out. Haven't seen it happen personally though. I always use Permatex on my freeze plugs. You can coat the inside to prevent rust, but with a properly maintained cooling system that should not be an issue.
    Next topic: the difference between core plugs and freeze/expansion plugs.
  5. ronnieroadster
    ronnieroadster
    Br*** is much better lasts forever unlike steel thats rusts away even when coated.
  6. stimpy
    stimpy
    I built a couple inthe 1980's that when I put the frostplugs in I used indianhead shellac on the backs of them , no rust thru yet . and one of the motors is run with straight water . I like br*** as it forms to the hole better if its old and rusted , but had good luck with steel units too .
  7. freeze plug
    freeze plug
    from Canton, CT
    I am sorry that I can be of no ***istance to you
    dogwalkin likes this.
  8. trbomax
    trbomax
    I like the cup style br*** ones with permatex #2. If the block hasnt been tanked and the holes are dirty/rusty you will need to clean them up with a small br*** wire wheel on a drill or preferably an air grinder. Core plugs and #2 wont hold in a dirty.rusty hole.
  9. HOTRODPRIMER
    HOTRODPRIMER
    That's funny,and a name like freeze plug!:D HRP
  10. squirrel
    Steel, and use sealer.
    And the strange thing is, we both are right.
  11. Don's Hot Rods
    Don's Hot Rods
    from florida
    I've worked in the marine business for years so I always use br*** ones. Most machine shops can get them for you, maybe even NAPA and other auto parts stores too.
    I also coat the mating surfaces with Permatex.
    Don
  12. squirrel
    Br*** plugs are great if you don't maintain your engine.
  13. jkeesey
    jkeesey
    Has anyone used the new expanding rubber plugs? I used them in an old jeep where access was an issue. They also worked nicely for plugging up valve cover holes.
  14. I have used expando plugs where a rotted out soft plug was in a hard to reach area and pulling tghe engine was out of the question. I would not use expando plugs in an engine that was out of the vehicle.
    I like br*** but I don't think that they are any better then steel.
  15. GRX
    GRX
    from MD
    Agreed. Expando rubber plugs are just for a quick fix, not long-term. And they are certainly nothing new.
    There is a technique to removing steel & br*** plugs. Cannot remember how many engines I have built where someone just punched them all the way in and installed a new one. Can you say blocked coolant p***age? :rolleyes:
  16. bobss396
    bobss396
    We always used the br*** ones on boat engines, steel on cars. NAPA or whoever carries both. I did use an expandable behind a motor mount once, too cold to lift the engine at the time, and it was in there for years.
    Bob
  17. tred
    tred
    i was able to find BOTH sizes that my plymouth engine calls for in br***, and on the shelf at a napa store.
    the br*** is more forgiving and will work better for an engine that wasn't all cleaned up properly.
  18. As Squirrel inferred, system maintenance makes either one work well and last a life time.
