which frontend for my 49-3100
Discussion in 'The Hokey Ass Message Board' started by taylor800r, Sep 18, 2011.
  1. taylor800r
    taylor800r
    I know the mustang 11 frontend is a common piece, but whats my options other than that,some say use the z-28 camaro and some say s-10! anybody use one of these,how's the best way to join these chev front clips any info of photos thanks.
  2. guthriesmith
    guthriesmith
    I would suggest a dropped axle from 55 Mercury here on the HAMB www.droppedaxles.com
    There are lots of pics and a tech article of how to do it on your truck.
  3. Cymro
    Cymro
    Jaguar xj6 or xj12, big brakes, and virtually bolt in.
  4. JustJoey
    JustJoey
    Depends on what you are after with it. Ride quality? Ride height? Wide wheel/tire? Brakes?
    Camaro clips are a little wide unless you want to run a narrow wheel up front. Limited and expensive options/parts.
    S10s are a little narrow unless you want a wide front wheel. Great ride, very versatile, cheap parts.
    MII are also on the narrow side, ride varies by spring rate also very versatile.
    Stock with dropped axle is a good option if you arent concerned with ride quality, handling. There are brake upgrades for stock axle out there also.
    I have a 50 on a S10 frame. Truck had a camaro clip when I bought it but I was unhappy with the stance and wheel options. Mine is on air ride now with 8" wheels up front and im very happy with the results. It was a lot of work though.
