Which GM Manual Transmission?
Discussion in 'The Hokey Ass Message Board' started by mink, Jan 16, 2012.
  1. mink
    mink
    from CT
    Hey fellow rodders currently with my hotrod project I chose a to run a later T5 5 speed (from a 86camaro) with my engine choice a 250ci straight 6 chevy. I bought the transmission for $400 .
    Did i make a wise choice? or should i search for another. The plan for the 4dr 32 chevy was to make it a cruiser and not be hard on it. but i think that may be hard to abide by.
    Will the ****** hold up to the stock torque my straight 6 is dishing out?
    What would be a better choice? Preferable I would like to have the ****** be light in weight.
    Do i need to look at a top loader 5 speed?
  2. Hnstray
    Hnstray
    from Quincy, IL
    The T-5 should be just as, or more, reliable in your '32 Chevy as in it's original application. It's probably the lightest weight suitable 5 speed trans. Sounds like a good choice to me.
    edit: While the general info above is okay as far as it goes, there is a difference between T-5 trans from early to later versions. The earlier are referred to as NWC (non-World Cl***) and the later WC (World Cl***). The difference primarily being in the bearings vs bushings as I recall. However, that difference does allow for a little more torque capacity.
    Also, there are various gear sets with 1st gear from slightly over 4 to 1 to about 2.95 to 1 and also significant variation in 5th Overdrive ratio as well. So, picking the T-5 with a ge****t that works best for your application (i,e, rear end gears, tire size, engine torque etc.) is important in achieving satisfactory results.
    Go to www.BritishV8.com for a complete listing of applications, gear set ratios and codes that identify them. Enter Borg Warner T-5 in search box.
    Ray
  3. inliner2318
    inliner2318
    from Tyler, TX
    Take a look at the inliners.org site on the hybrid T-5. Good choice.
    Oh.... I see you did.
    Best engineer is ME ;)
