Technical Which master cylinder
Discussion in 'The Hokey Ass Message Board' started by 50 COUPE, Feb 25, 2019.
  1. 50 COUPE
    50 COUPE
    Going to do the brakes on my 59 F100 Panel soon. Plan to run drums all around, like stock, but would like to swap to a dual reservoir master cylinder instead of the old fruit jar that it has now. What worked for you and was it a pain to do? Clutch master will be removed since I plan to run a C4 auto trans. Looked at a 70 model Mustang that seems to be right for this swap. Just wanting opinions on the job.
  2. tb33anda3rd
    tb33anda3rd
    match the bore size of the original.
  3. bobss396
    bobss396
    Get a '68 Ford truck drum-drum master. Make sure it is for an F100, the bigger truck ones (F250, F350) are different.
