Technical Which model A do I have?
Discussion in 'Traditional Hot Rods' started by Spike788, Jul 22, 2022.
  1. I'm certain I have a 29 Model A. Just not sure if it's a sport, standard, etc. All I know is that it's a 29. Has been chopped. Can anyone help determine that for me? Asking so I know which interior wood kit to buy. Much appreciated.
    dana barlow likes this.
  2. 19Eddy30
    19Eddy30
    from VA
    Std Coupe,
    Is there wood still in ,
    Roof
    Rear window
    Quarter windows
    Above door
    Header wood above windshield
    B pillar afew other places ,
    Most of the A venders should have break down on wood locations.
    osage orange likes this.
  3. HOTRODPRIMER
    HOTRODPRIMER
    Yeah, it's a coupe. HRP
    Dave Mc and dana barlow like this.
  4. I have no wood as is. Just need to know which particular model (standard, sprt, special, etc) so I know which wood kit to buy. I basically just want to install enough wood on the interior (especially around the windows) to get the upholstery done. Or do you have to install the entire wood kit on the interior? Is it possible to just install the wood around the windows only?
  5. D-Russ
    D-Russ
    Yes, it's a coupe, but the bead that runs under the quarter windows and back window has been removed for some reason. I'd be curious what's under that insulation.
    Stogy, osage orange, Tman and 3 others like this.
  6. Corn Fed
    Corn Fed
    I bet it started out as a "leatherback" coupe which had a lot of wood holding the quarter window panels and basically made up the whole rear window. But someone installed the rear window section most likely from a sedan to make it all metal. Under all that insulation you will find a bunch of welds.
  7. dmar836
    dmar836
    Looks like it might have started as a “Special Coupe” and someone just welded the top on.
  8. RICH B
    RICH B
    The are garnish moldings that go around the quarter and rear windows, should round up a set of them and chop them to match. When looking be aware that '28 & '29 are different than '30 & '31.
    From the work shown in your pictures; I would think it would be easier making your own pieces vs. trying to make original type pieces work.
    Most importantly; I would have your trimmer look at it and see what he needs.
  9. Hitchhiker
    Hitchhiker
    I responded on your Reddit post, but I have a set of garnish moldings for that thing...
    Stogy likes this.
  10. RB35
    RB35
    Try Bratton's website for parts. They sell wood kits too.
  11. 19Eddy30
    19Eddy30
    from VA
    Like other mention if not originally standard coupe model , wood different other models of coupes , so you will have to do research on what wood same then make own or modified pieces not
  12. Stan Back
    Stan Back
    Moving the radiator back towards where it came from would make it a lot more handsomer.
    Jibs and X38 like this.
  13. hotrodjack33
    hotrodjack33
    Hmmm...yeah, that's not a Standard Coupe. Note the missing beltline under the 1/4 window that should run all the way around the back of the roof. That body was a Special Coupe or a Sport Coupe with a roof added to it. 0.jpg 0.41.jpg
    mgtstumpy and trevorsworth like this.
  14. Hotrodmyk
    Hotrodmyk
    As above, I have to guess it started as a "Special Coupe". Too much around the back has been changed.
  15. sloppy jalopies
    sloppy jalopies
    putting my money on it being a std coupe, sedan rear window [they removed the qtr to tulip T strips...]
  16. Ok fellas. Thank you. Anyone else? Trying to get as much input as possible. I appreciate any further thoughts from anyone.
  17. Since it seems slightly unclear as to exactly what parts your coupe is made up from, if I were in your position I think I'd be inclined to study pics of how Model A's are wooded then make my own wood components.
    dmar836 and osage orange like this.
  18. pprather
    pprather
    It looks like the structural wood has been somewhat replaced with 1"x1" tubing. Can you confirm?
    I would start, as suggested, by figuring out how you will mount the quarter and rear window garnish mouldings.
    In addition to adding structural support, the original wood provided a surface to tack the interior cloth and screw the garnish moldings.
    Stogy likes this.
  19. Yes there is steel tubing along the interior roof.
    Stogy likes this.
  20. panhead_pete
    panhead_pete
    Post more pics of the interior after removing that insulation, almost looks like its been partially steeled out.
    If its structually sound why do you need a wood kit?
    Stogy likes this.
  21. Stogy
    Stogy
    He wants interior attach points...I'm not up on interior installs but anchoring panels to framing gives a glue and screw base...question is, is there enough tubing.
    The other question is, is there enough tubing installed to take care of what the wood did as it was structural and well as an interior attach point as @pprather said
    My 29 Sport Coupe has no wood with metal added to replace the removal...I have many interior panels still lacking and will have to be crafty should I ever add them.
  22. alchemy
    alchemy
    You bought somebody else's unfinished hot rod. They made unusual modifications to that leatherback coupe body, and no stock wood kit is going to fit directly in there. I think it's close enough to a steelback now that you could start with a steelback kit. But be aware there will be modifications needed.
    Or, if you are a good woodworker, maybe you can craft your own from pictures. There are plenty of restorer websites with pics posted of the guys installing wood. I recently made the rear window surround wood for a 32 five-window instead of buying a kit, because I wanted it different than original. Took me about $20 in good lumber, and a couple evenings of work. I have a table saw I used for the overlapping joints, and a bandsaw to cut the curves in the openings around the window. A beltsander will be handy too.
    X38, X-cpe and Stogy like this.
  23. Stogy
    Stogy
    :rolleyes:...this video showcases a Special Coupe to Coupe conversion but your's has drip rails added or the complete roof may be a donor...
    The video also shows the roof without it's Vinyl which exposes attach points that may be present under your interior noise/weather proofing...​
    Maicobreako, footbrake and dmar836 like this.
  24. footbrake
    footbrake
    What a beautiful job you did.
  25. Mo rust
    Mo rust
    You can tell if it's a regular coupe or a leatherback by its production date. What's the vin with the except for the last few numbers?
  26. Corn Fed
    Corn Fed
    How can you do that?
  27. indyjps
    indyjps
    The car has been modified enough that regular wood kit won't be direct fit.
    Wood kits are expensive, if you end up only using a little of it or still modifying it, you'll be pissed
    Let's see it without insulation.
    Best option may be to keep going with steel. If you have light box section of steel, you can plan your interior panels to use plastic christmas tree clips to pop into holes in steel. Can also use stainless shouldered washer screws - you can buy them with caps, look at some marine upholstery places, all kinds of cool stuff.
    Snap panels on like a boat cover too.
    There was a great thread recently on making fibergl*** headliner - they need to be split to fit into car.
    Consider you could lay up vertical interior panels with attachment points - As the base to cover with upgolstery..
    X38 and ClarkH like this.
