which spring can i fit into a mdl a rear crossmember
Discussion in 'The Hokey Ass Message Board' started by len_m, Jan 29, 2006.
  1. len_m
    len_m
    from wpg,can
    what year type (front,rear) spring can i run with a stock rear crossmember for my model a. i was doing some reading and saw that some of them won't work because it will hit the frame when under load. is there one that won't? if i really have to i will extend the frame. the car will be full fendered. and if that doesn't work wheres a good site to order a stock rear spring
    thx
    len
  2. len_m
    len_m
    from wpg,can
    back to page 1
  3. alchemy
    alchemy
    Stock Model A's and Model T's would work in an A crossmember. The T is a bit thinner, but should still work OK. It has been done many times in the past.
    The only place for new springs I know of is Posies, and they do the A but not the T. But Posies has those ugly warts on it.
  4. woody
    woody
    I think speedway has a "high arch" model A/T spring for about a hundred bucks.
    Woody
  5. len_m
    len_m
    from wpg,can
    yeah i had already looked at the posies ones. i guess i didn't explain myself clearly. i read that some late 30s-late 40's springs (front and back) will fit in the crossmember but once under load they won't work because the spring with hit the frame where it curves. is there a 30's/40's spring that won't hit and fit at the same time while being mounted ontop of the axle. or if i were to modify the crossmember and remove the arch so that it was just flat and then run the 40s spring. would that work fine?
    thx
    len
  6. If you put a late spring on top of a Model A axle (original mounts) it will hit the banjo (center section). A late spring will not seat in a Model A rear crossmember. Just will not work.
    There are only three ways to get a Model A rear end down with the rear spring in the stock location; reversed eyes, a stepped frame or a "Zeed" frame.
    Reversing eyes and stepping frames are discussed in Mike Bishop's book. Zeeing is like stepping only more extreme. Stepping and zeeing require floor sheet metal modifications.
    Another way is to use the Model A rear spring in conjunction with a 37-40 spring behind axle. To do this you have to extend the frame rearward about 8". Lots of fabrication and sheet metal work. And axle-frame clearance is an issue.
  7. len_m
    len_m
    from wpg,can
    but what if i took the hump out of the rear crossmember, and made it flat, would i be able to fit the 40's spring in there with out frame hitting problems..i don't see why that wouldn't work. it would be as if i had just put a piece of 3x3 tubing across the back to mount the spring too.
  8. woody
    woody
    If you want to use the piece of 3"X3" you can just remove the model A cross member and sell it to some one who wants it.
    However the rear spring from a '40's ford will hit the top of the banjo center section(as stated by Bib overalls). Unless you mount the spring behind the axle. That is how they were all done after 1931.
    I guess Henry moved the spring behind the axle to make more trunk space?
    Woody
