Well , my orig 34 spring perches are trashed. I need to buy some aftermarket forged spring perches. I am using these on a ford axle with original reversed spring. If I do not find another set of original perches can anyone recomend a good aftermarket choice? Should I go with adjustable perches? Was hoping to get some good advice on this. thanks
Any place that carries old Ford parts should have new perches, Macs, Speedway, etc. . . http://www.speedwaymotors.com/Axle-Spring-Perch-Plain-Forged-Steel,2081.html Personally I don't like the look of the adjustable perches, but that's just me.
we carry the forged perches and the stainless ones (both polished and unpolished). the adjustable perches are great for cars running stock front crossmembers with big & littles because it's virtually impossible to get the caster right without binding the spring. if you are running an aftermarket crossmember or you aren't running a big rake it is probably unnecessary.
