Technical Which transmission for an AV8?
Discussion in 'The Hokey Ass Message Board' started by NB141FD, Nov 14, 2015.
  1. Better gear ratios. Rodders have been doing that since the day after dirt.
    Hotrodmyk likes this.
  2. What is a better gear ratio? A closer difference between gears is important for racing (which is what the Lincoln gears have in addition to a higher first gear) but if the person wants to run a high rear end for freeway driving wouldn't the lower first gear of the standard car be better? I must admit I don't know the answer. I do agree that rodders have been using the Lincoln gears since the day after dirt and that has driven the price up. For a street car with a high rear end, are they worth the premium?
    Charlie Stephens
  3. I found an article that better explains it then I would. Here is an excerpt to save you from scouring the entire article:
    The standard Ford-Mercury boxes have a 28- or 28- tooth main driving gear. The Lincoln Zephyr box carried a 25- or 26-tooth main gear. The lower ratios available in the Zephyr first and second, produce a higher gearing and permit a higher maximum speed in first and second, without changing the speed possible in high (or direct). In addition, Zephyr ratios are closer than in Ford-Merc boxes. As a result of Henry Ford's feeling for standardization, Z gears are interchangeable in most Ford and Merc boxes.
    You can draw your own conclusions, but I wouldn't let the energy crisis of the '70s sway you too much this is hot rodding 101 which has little or nothing to do with economy. :D
    Here is a link to the entire article which is pulled from Speed mechanics circa 1955:
    http://www.btc-bci.com/~billben/lincoln.htm
