Customs Which wheels ?
Discussion in 'The Hokey Ass Message Board' started by shonky, May 17, 2017.
  1. shonky
    shonky
    from Norfolk UK
    I want to put sombrero style stainless hubcaps on my 47 ford but not sure what wheels I need to use ?
    I want To use 15" rims on 40's ford hubs , I know I will have to modify the hubcaps but think standard ford rims are too shallow to take a sombrero!
    Any help appreciated
    Keith
  2. Sheep Dip
    Sheep Dip
    from Central Ca
    Your looking at a 15" 54'-55' Caddy Hubcap on a 5" wide wheel with a 3" back space. 3" B.S. is about the max. Have all your weights put to the inside for a good even external fit.
    shonky likes this.
  3. shonky
    shonky
    from Norfolk UK
    Thanks
    It was which wheel I can use , that will fit a sombrero style cap
  4. Hnstray
    Hnstray
    from Quincy, IL
    Considering the wheel covers you want to use, you need a wheel center with the least 'shape' protruding to the outside. Those accessory 'wire basket' wheels come to mind. Not the fake wire part, but the concave shape of the wheel center that may more readily accept the sombrero cover without interference.
    At the moment, I can't think of any OEM wheel with the 4.5" bolt circle that meets that criteria. Older Buick, Pontiac, Olds and Caddy wheels would accept the cover, but are all 5" bolt circle. Lastly, you could get wider aftermarket wheels with more 'front spacing'. Trailer wheels often have that more concave shape, are usually 5" or 5.5" wide and are readily available in 4.5" bolt circle.
    Ray
    shonky likes this.
  5. gimpyshotrods
    gimpyshotrods
    Like this, Ray?
    Hnstray and shonky like this.
  6. Chavezk21
    Chavezk21
  7. Chavezk21
    Chavezk21
    That style as well as the old modular, and white/black spoke have worked for me.
    shonky likes this.
  8. gimpyshotrods
    gimpyshotrods
    shonky likes this.
