Which year crank pulley required?
Discussion in 'The Hokey Ass Message Board' started by mccarrol, Feb 18, 2004.
  1. mccarrol
    mccarrol
    I used the Vern Tardel book to locate my engine mounts for my 53 in my 29 frame. I have a dual pulley which is too long and hits my spring U bolts. I see his flathead is a single belt pulley. Can someone steer me to the correct years to use? Thank you.
    Joe
  2. Bruce Lancaster
    Bruce Lancaster
    First, what pumps are you using? Early pumps can be used on the late engines with simple changes to shorten the pulley area.
  3. mccarrol
    mccarrol
    Bruce, I'm using 49-53 truck water pumps.
    Joe
  4. Digger_Dave
    Digger_Dave
    [ QUOTE ]
    Joe
    [/ QUOTE ]
    When looking at the pumps from the side, are the pump pullys OFF SET? (the belt groves not in line with each other)
    Are the belts WIDE or NARROW?
  5. mccarrol
    mccarrol
    Thanks for the interest. The pumps have no offset and the pulleys are wide. I'm going to be away for a week, so I will answer all when I return.
    Joe
