Whiny transmission
Discussion in 'The Hokey Ass Message Board' started by DJR13, May 30, 2008.
  1. DJR13
    DJR13
    from Venice, Ca
    53 chevy with 235 and standard transmission.... 3 speed. Trans whines when driving. Is this the nature of the beast? Did they whine like that right out of the show room back in the day or what?
  2. bryan6902
    bryan6902
    How's the fluid? Changing your fluid and making sure you have the right stuff in there might be all she needs. Could also be a throw out or pilot bearing on it's way out.
  3. JohnEvans
    JohnEvans
    from Phoenix AZ
    3rd should be quiet, 1st and 2nd will make some noise. If 3rd is noisey most likely wrong lube or bearings going. As above also make sure T/O bearing is not turning with the clutch engaged.
  4. DJR13
    DJR13
    from Venice, Ca
    3rd is quiet. 1st and 2nd noisy. I guess all is well. Just changed fluid. Used 90w gear oil. Throw out bearing does clank around when clutch is engaged. Guess I'll let it clank until I can't stand it any more! Thanks for the info
  5. Mr48chev
    Be careful with that. When they do decide to lock up or come apart they like to take other things with them.
