Technical White color 2k epoxy sealer/primer
Discussion in 'The Hokey Ass Message Board' started by JD Miller, Oct 8, 2024.
  1. JD Miller
    JD Miller
    Without checking myself....... lazy
    Is a white color epoxy primer/sealer available?
    Just Gary likes this.
  2. KenC
    KenC
    Yes, it's available. Using it now on my pickup, Kirker brand. Other brands are also out there.
  3. JD Miller
    JD Miller
    Cool ...thanks !
  4. TerrytheK
    TerrytheK
    Another option courtesy of your local PPG/Omni paint supplier:
    RMR&C likes this.
  5. Ppg has white as well
  6. pbr40
    pbr40
    from NW Indiana
    Tamco has white sealer
  7. Moriarity
    Moriarity
    SUPER MODERATOR
    Tenaco brand epoxy primer by Viking paints in bloomington , Mn . this is the same stuff that is repackaged and sold by Squeeges rod shop. This place was on my way home from work and I used to stop there and buy it.. And don't tell anyone but it has ZINC in it!!! you heard me.... and they have white. last time I bought some (maybe 4 yrs ago?) it was 150 bucks for 2 gallons sprayable... and no you can't order it online, you have to CALL them
    https://vikingpaints.com/products/tenaco-epoxy/
  8. Sharpone
    Sharpone
    I bought some SPI white epoxy less than 200 a gallon for primer and activator dries to almost satin finish. I bought through a local distributor that SPI put me in contact with, charged me less than SPIs internet price. People I know that have used this product have been very happy with the results.
    @Moriarity that primer with zinc , is it similar to the old zinc chromate primers?
    Dan
    klleetrucking likes this.
  9. Moriarity
    Moriarity
    SUPER MODERATOR
    https://vikingpaints.com/product/tenaco-epoxy-50-primer/
    SS327 and Sharpone like this.
  10. It's also a great high-build primer when reduced less & sprayed through a 2.3 tip.
    Sharpone likes this.
  11. CRE epoxy can be purchased in white.
    It’s a mild build primer
  12. KenC
    KenC
    The zinc is probably in the form of zinc oxide. A strong colorant that is pure white. Remember the old sunscreens that were a thick white past/cream the made your nose look brilliant white. Yep, zinc oxide.
  13. Moriarity
    Moriarity
    SUPER MODERATOR
    since nobody cares to click the link I posted above
    TENACO® EPOXY has been field tested since 1964. It contains zinc phosphate pigment as the anti-corrosive agent.ASTM B-117 test for rust creepage away from x-scribe on steel panel: rating of 9 on a scale of 0-10. 0-worst, 10-best. It is used as a rust inhibiting metal primer
    SS327, Just Gary and Sharpone like this.
  14. Doublepumper
    Doublepumper
    from WA-OR, USA
    Hey! I'm a nobody and I clicked on it! :D
    Sharpone and Moriarity like this.
  15. Sharpone
    Sharpone
    I’m a nobody also! thanks for the link.
    Looks like good stuff and at reasonable price
    Dan
    SS327 and Moriarity like this.
