White Primer
Discussion in 'The Hokey Ass Message Board' started by InjectorTim, Mar 27, 2006.
  1. InjectorTim
    InjectorTim
    Hey guys, I'm going the flat white with red wheels/accents route on my Buick, what are some white primer/sealers available?
  2. Slide
    Slide
    Sure you want primer? If you're gonna park your car in the sun much, I'd strongly suggest flattened white paint.
    If you're planning on re-spraying the car fairly soon, there's a white version of DP90. Just change the "90" part to a different number... can't remember which it is. But DP fades the fastest of any primer I've seen.
    PPG's K36 is an off-white gray. It's a surfacer that sands nice, and I like the way it shoots. It's what is on my car around the frenched lights in this pic:
  3. InjectorTim
    InjectorTim
    I plan to eventually paint it white, but want the same effect until I have the time to do the bodywork.
    I wonder, if white primer faded, would anyone notice?
  4. yea, what Slide said.
    Preferably K 38 (the replacement for 36). Get it covered in that, then a coat of DPLF white(it's either DPLF 48 or 50, I forget, and I don't wanna walk to the back of the shop to find out) FWIW, white epoxy don't cover worth a damn, so light gray primer all over first will help take less epoxy to get the desired result.
  5. Spridle
    Spridle
    DP40 green, like an army drab
    DP48 white
    DP50 gray
    DP60 blue, pale smurf
    DP90 black
  6. burntclutch
    burntclutch
    from N.E. La
    have you checked out kustom shop hot rod flatz,its not a primer but its pre mixed and ready to spray,an e-bay store called auto body depot is where I saw the stuff at,was think'n about try'n some out
  7. ray
    ray
    from colorado
    i think a bigger issue than fading, is with white primer, if you have dirty hands and even LOOK at your car, it will leave greazy fingerprints!
  8. 7&7
    7&7
    from Colorado
    My bud used Dupont white with a flattener. It doesn't collect smudge as bad and it is sealed. I used ppg and had the paint store make it flat (purple) it is nice as hell. I would use paint instead of primer. At least you know it is sealed when you are done. You think body work is a ***** wait till next time.
  9. chopolds
    chopolds
    from howell, nj
    Dupont "Corlar" is a 2 part epoxy primer. Comes in light grey, which in reality is closer to white than grey. I used to use it for pastel color primer (with toner added). Epoxy is pretty water resistant, has a bit of gloss, which makes it easier to clean than other primers.
  10. InjectorTim
    InjectorTim
    good info, thanks guys.
  11. NickGee
    NickGee
    Spiezhecker makes an awsome primer any color you want. It is activated with a catalyst , preventing it from fading or absorbing moister it is called Spectro surfacer. Look at Nick32vic's car.
