Whitewalls turning brown??
Discussion in 'The Hokey Ass Message Board' started by 56gasser, Apr 11, 2010.
  1. 56gasser
    56gasser
    from lower al.
    I have a set of whitewalls on my piecrust slicks that are turning brown/tan! Does anyone have a good fix? They offered to fix them, but I would have to dismount them and ship them back, plus mount them again. That is quite a bit of money. Or they would send me 40.00:(, thats not worth the trouble of turning the around!!
    Clyde
  2. some Wesley's Bleche-White won't take care of it? It probably depends on why they're turning brown, if it's a manufacturing issue, or just something getting on the tires, dirt, mold, whatever. Won't the tire manufacturer tell you what they do to "fix" this?
    I suppose if it came down to it, you could just paint them white again, but that's kind of a cheesy way to fix it.
    Also, somewhere in here there's a line about them being ****ty tires...
  3. 56gasser
    56gasser
    from lower al.
    They said try bleach. That didn't work either!!
    "Also, somewhere in here there's a line about them being ****ty tires..." Thats what I was thinking!
  4. You need to tell us who makes/sells the tires...so nobody else has to go through the same thing...
  5. slamdpup
    slamdpup
    castrol super clean..(purple bottle)...or brake cleaner..but the brake cleaner will remove some of the white..dont use it alot..just for tough stains
  6. 56gasser
    56gasser
    from lower al.
    I will try the brake clean. I bought them off egay!! They were Towel City retreads.
  7. Butch11443
    Butch11443
    Use the purple floor cleaner and a sos pad. Aleays worked on my wide whites.
    Butch
  8. Weasel
    Weasel
    The brown is from the adhesive/chemicals leaching through the tire - it will always come back. Sorry but that's the way it is.
  9. 60 Duce
    60 Duce
    Well I'm glad someone brought this up I have Coker Bias Plys bought in December three of the tires are bright and one is turning brown on the outter perimiter of the whitewall so far the place i bought them at has let me return it twice I'm now on my third tire and its starting with maybe 80 miles on it. I tried switching sides meaning first it occurred on drivers side and now on the p***enger side I'm stumpped its just the one tire and three new returns are doing it! WTF!!! I'll try the sos and brake clean but its a brand new tire, damm it Jim :mad: Also I understand about the natural leaching but only one tire and its way too soon
  10. claymore
    claymore
    Good old Brillo pads usually work real good with some elbow grease
  11. model.A.keith
    model.A.keith
    I use Autoglym Engine cleaner...and wipe off seems to work ok, it was a tip p***ed to me by someone who has used it for 15+ years or so .........
    '' Autoglym Engine & Machine Cleaner is a powerful, non-corrosive cleaner for engines, components, wheels and machinery.
    Simply spray on, brush and hose off to rapidly dissolve oil, grease, grime and traffic film from all surfaces.
    It works as a combined detergent and degreaser. Harmless in contact with plastics, rubber, paintwork and metal, it cleans the complete engine bay quickly and safely.
    Autoglym Engine & Machine Cleaner is solvent free, water based and bio-degradable.
    Also use to clean anodised, non original or specially plated wheel finishes.''
  12. My Cheater slix are turning brown on the outer perimeter and they've seen......ZERO miles.
    Just mounted.
    Not impressed really....
    Rat
  13. Muttley
    Muttley
    What brand are they?
  14. Paulie9fingers
    Paulie9fingers
    I have the Firestones from Coker and I clean mine with a stiff scrub brush, Super Clean and soapy water. They're 2 1/2 years old and as still white as the driven snow. I have also used SOS pads with soap on some of my other white walls, just no need to on these yet, the Westley's works well too.
    This is when they were first mounted;
    This is them today;
    I remounted them on different wheels and a different car, they have right around 1000 miles on them.
    Good luck
  15. TMoney
    TMoney
    I've always had good luck with S.O.S. pads, the blue ones with the soap already in them. It sounds too rough but the soap actually keeps the pad from scratching. It works good for chrome too.
  16. Bull
    Bull
    We have a super strong cleaner and degreaser product that would likely work for cleaning white walls called Crud Release. I haven't tried them on my Firestone bias ply wide whites yet but I'd think it'd work great.
  17. Side
    Side
  18. chaos10meter
    chaos10meter
    from PA.
    Have you tried Simple Green , works good on mine.
  19. LOWCAB
    LOWCAB
    from Houston
    water, comet cleanser, bristle brush, rinse.
  20. oldpl8s
    oldpl8s
    I use the Westley's with good results. You can see the brown dissolving when the spray hits the tire, then scrub them and rinse off.
  21. Paulie9fingers
    Paulie9fingers
    . . . gotcha.
    He said they were retreads, I wonder what core they started as. I'm not doubting you at all (I don't even know what a plasticizer is :D), just trying to learn, what would be leaking out from behind the whitewall if the whitewall was already existing prior to them re-treading the tire.
  22. HOTRODPRIMER
    HOTRODPRIMER
    I have used this product for years,,first on blackwalls and then found out how well it works on whitewalls.
    Spray on dry and let it soak,,use a stiff bristle brush with very little effort and hose off,,,works great for me. HRP
  23. HOTRODPRIMER
    HOTRODPRIMER
    Another thought,,many years ago a friend who was employed with a large tire manufacturing plant commented on how my blackwalls had a brownish tint and no matter how many times I washed them it kept coming back.
    He explained that if I wanted to get them clean and keep them rhat way,,,get some Naptha and wipe them down,,,It solved the problem. HRP
  24. Chances are, even though the tires are recaps, they've had the whitewall vulcanized over the black wall case. This is and has been a very common problem on white walls vulcaniced onto a black wall tire. If the tire was made AS a white wall, or had a RWL shaved to make the white wall, then no problem. The problem seems to be with the white rubber compound that's vulcanized to the tire. I believe Diamondback adds a Butyl rubber compound to the black wall case before they add/vulcanize THEIR white walls. This supossedly eliminates the problem, although I have NO idea if this is true or not...
  25. ol'chevy
    ol'chevy
    Yes, this is the blackwall tire leaching through the whitewall. it is coming from within, and will not clean off. Diamondback uses a butyl layer under their white rubber to prevent this. I have heard many stories of cokers turning brown, the ones I had did this. My diamondbacks still look great, I don't even clean them as frequently as I should. I drive the piss out of them.....
    http://uk.youtube.com/watch?v=RaeeNhbWsuc
    http://www.youtube.com/watch?v=7zEhDLhWaAA&feature=channel
    I have one that is splitting in a small section of the whitewall. I called Bill, new one will be here next week. They have GREAT customer service. This is why I have bought 5 sets for my self , my friends and clients.
  26. ol'chevy
    ol'chevy
  27. Rockettruck
    Rockettruck
    I had a set of wide whitewall cut into a set of tires years ago. Two of the tires were brand new Firestones and the other two were another brand that I had bought a year or two earlier. The older tires cut and "whitewalled" great and lasted at least until I sold the car a few years later. The newer tires leached the brown stuff and never would clean up. The tire guy had never seen it happen to his cut whitewalls before...he redid the tires twice...
  28. OL'CHEVY - That string of photos of Diamondback making their white walls http://picasaweb.google.com/rpettycustommurals/DiamondbackTour did it for me...PERIOD! I've been searching for the "Right" tires for months, and I can't afford to piss close to a Grand away on substandard white walls...NOT meaning to Hi-Jack the thread...
  29. ol'chevy
    ol'chevy
    Trust me....they are THE tire to drive on. Even ******Knuckles admitted that they drove great on his wife's DeSoto.....radials!
  30. adamatson
    adamatson
    from illinois
    If the tires were ever stacked with the black side of one on top of the white side of another this will cause them to brown, and the brown will never come out.
