Technical Who carries quality grease gun tips?
Discussion in 'The Hokey Ass Message Board' started by Budget36, Dec 10, 2020.
  1. Budget36
    Budget36
    Mine are pretty worn after the years. I recall the day I could just push them on and pump away. Now I’m tired of using 3 hands to hold the tip onto the zerk.
    I went to NAPA store, same brand as hanging on the AZ shelf. Not sure if worth a **** or not
  2. 62SY4
    62SY4
    from Irwin, Pa
    For standard jaw couplers Lincoln-SKF or Alemite-SKF.
    There are all kinds of fancy locking types out there as well, if you are into that kind of thing.
    Budget36 and VANDENPLAS like this.
  3. ekimneirbo
    ekimneirbo
    from Brooks Ky
    The locking types are great.........
    triumph 1 and VANDENPLAS like this.
  4. AccurateMike
    AccurateMike
    VANDENPLAS, Budget36 and seb fontana like this.
  5. Wrench97
    Wrench97
    Except where they don't fit....................
    VANDENPLAS and Budget36 like this.
  6. Budget36
    Budget36
    Ya. Was about to pull everything off and refit wit old Cat stuff, you slid it over and it locked in. The realized I would be able to turn the wheels anymore. lol.
  7. Budget36
    Budget36
  8. Wrench97
    Wrench97
    Alemite 308730-A with a internal check valve or 308730 without, they are on Amazon.
  9. kadillackid
    kadillackid
    I also need this info...thanks :rolleyes:
  10. bobss396
    bobss396
    I get the ones that are impossible to remove off the fittings once I'm done greasing them. It takes a pair of vise grips and a hammer at times.
    warbird1 and weeniewawa like this.
  11. Wrench97
    Wrench97
    Loosen the tip of the fitting.
    weeniewawa and 62SY4 like this.
  12. onetrickpony
    onetrickpony
    from Texas
    I got tired of that years ago and bought a pistol grip grease gun that I could work with one hand and hold the hose with the other.
    X-cpe likes this.
  13. Joe H
    Joe H
    Budget36 likes this.
  14. 1971BB427
    1971BB427
    from Oregon
    I just converted one of my grease guns to a locking tip, and love it! I've still got my compact one hand grease gun to get into tight areas, but I use the locking tip on my big gun with a flex hose for 95%, and it works fantastic.
  15. Boneyard51
    Boneyard51
    I’ve got several grease guns, one with a slightly bent tube , one I made with pipe fittings that goes out about eight inches and had a right turn and a fitting. One with a flex hose and an air powered one with a flex hose and a pistol grip wit a flex hose. Which one I grab depends on the job.
    My friend has a cordless battery powered grease gun that is real handy!
    There are some new locking tips that are supposed to be good, but I haven’t tried them yet.
    Bones
