Technical Who does their own chassis blue prints?
Discussion in 'The Hokey Ass Message Board' started by Frames, Nov 13, 2023.
  1. Frames
    Frames
    2023-11-12 21.02.05.jpg img450.jpg View attachment 5894022 View attachment 5894022 Most the time I do a concept drawing first. Then a 1/8" = 1" scale drawing. On this one I even drew in the steering U-joints. I drew it up at 107" wheelbase. I drew in a ghost and discovered I would have to shorten my legs from my knee to my foot. Not an option so I built the car at 110? W B. #25. [ Now #525 ] My concept drawing. img600.jpg img599.jpg 2023-11-12 21.02.05.jpg img450.jpg This is another trick I use. Worked with the copy shop until we obtained scale of Geo Montgomerys 100" W B. His chop 4". My chop 5.5" in back. 5" in front. Moved the tubs up 2" and forward 2". Run the car lower in back than this drawing. . View attachment 5894021 View attachment 5894022
    The37Kid, Thor1, das858 and 16 others like this.
  2. squirrel
    I did some drafting for Almost Funny.
    I even drew a scale slick to see if I could get it into the trunk with the ch***is design I had.
    The37Kid, Thor1, das858 and 11 others like this.
  3. Frames
    Frames
    Sharpone, kasselyn29 and dana barlow like this.
  4. Marty Strode
    Marty Strode
    This is as close as I come to drafting, however it does hold records at Bonneville and El Mirage. 2014-01-08 145052.jpg
  5. Dave G in Gansevoort
    from Upstate NY
    I make sketches of sub***emblies, and a future project is on the drawing board now. It's a redo of the ch***is and suspension from the 54 modified from 1976, updated to use dom instead of black iron pipe. I don't have bending dies for pipe...
    Sharpone likes this.
  6. 34Phil
    34Phil
  7. AccurateMike
    AccurateMike
    I use pencils and pixels.
    The dots lead to this
    I use my trusty AutoCad97 LT (I have to keep an XP/32 bit machine for it these days) to draw.
    It's handy for those pesky dimensions.
    It's nice to help visualize too.
    Lately I have been working on a cut file so I can curve my rails. I've decided to fab parts of the rails to fit the body and spring pads. I have a homemade CNC torch.
    I have used 2D cad to make all sorts of ****.
    I started drafting in Jr High. Through High School and 2 years of Community College. Just in time for early CAD to appear. I took Hewlett Packard CAD on DOS machines (my torch is DOS), just in time for the first AutoCad to come out. I gave up. I was sick of school. Back in the day, I used MAC CAD on a IICi to draw RC boats. Years later, an employer gave me the 97LT and I trained myself, it was worth it for him, he sent the other two to school. It will work forever on my old stuff. Mike
  8. guthriesmith
    guthriesmith
    I have on several things although not a car ch***is yet. I model pretty much everything I make in CAD then pull prints from that. If I ever build a complete ch***is, that would be my quickest way to make sure everything works.
    Sharpone and Ziggster like this.
  9. proartguy
    proartguy
    from Sparks, NV
    I did them when we built a frame for my son’s ‘38 Dodge 38 frame.jpeg Frame top.jpeg
  10. squirrel
    I used some DOS CAD programs 30 some years ago...it was limited in what it could do, but was still useful, I used it to design a frame for a 39 Studebaker. I don't think I have any of the drawings left, but I did see the car that was made from them, a couple months ago.
    I really like the 2D mockup. I've done stuff like that too
    Sharpone, Ziggster, alanp561 and 2 others like this.
  11. bill gruendeman
    bill gruendeman
    Wow, I can’t draw straight line with a rule. My plans are usually just in my head.
  12. lake_harley
    lake_harley
    I use a china marker and draw on the floor. Over a few days my skunk works drawings are erased by foot traffic. Finding a relatively non-chipped area on the concrete in my shop is becoming a larger problem though as years p***.
    Lynn
    Sharpone, tractorguy and Ziggster like this.
  13. lostone
    lostone
    from kansas
    ^^^ this ^^^
    Drew out my model A frame on my shop floor.
    Took a chalk box and made a line on the floor, this was my center line of the frame, all measurements were taken from this line.
    I made a white line that ran left to right, these lines showed where I wanted certain width measurements. Then I just made the cuts in the rails and bent them until the bends matched the outline on the floor and the measurements at the white lines matched up.
    Here a Pic but I had about worn the blue line away at this point...
    Sharpone, das858, Ziggster and 2 others like this.
  14. alanp561
    alanp561
    Next time, go to Home Depot and get some clear spray can enamel. After you set your chalk line, just run a coat of clear over it. Dries fast and lasts a long time. That's how I lay out guidelines for my walk behind concrete saw.
  15. LWEL9226
    LWEL9226
    from So. Oregon
    You could use red or black.... they are more resistant to wipe out.... some are even waterproof....
    LynnW
    Sharpone, lostone and rod1 like this.
  16. Frames
    Frames
    bttt
    Ned Ludd likes this.
  17. Marty Strode
    Marty Strode
    Dennis, you should write a book, with all the cars you built for people like Mark Martin and Rusty Wallace ! Maybe not HAMB friendly, but certainly historic.
    Sharpone, das858, tractorguy and 2 others like this.
  18. Ziggster
    Ziggster
    Went through my build thread and dug up a few pics of my drawings. Couldn’t imagine building anything without some sort of sketch/drawing.
    B78E0536-03D9-441B-B9C1-C97A0AE68E7C.jpeg 83ACE325-5FF1-4E2E-AF48-C6B69EF0DA36.jpeg
    Sharpone, rod1, AccurateMike and 2 others like this.
  19. squirrel
    this is what I tell the robotics students all the time....if you can't draw it, then you probably can't build it.
    Sharpone, das858, Ziggster and 5 others like this.
  20. Marty Strode
    Marty Strode
    Jim, that's probably true in most cases, but not in our family. My 3 brothers and I built at least 150 vehicles of all types, Dune Buggies, Sand Dragsters, all kinds of Drag machines, up to Funny Cars. Then on to Truck and Tractor Pullers, Oval Track and Land Speed, without ever making a scaled drawing. My oldest Brother Jerry used to say, "I can't draw it, but I can build it" ! This is one of 2 of these that he build around 1990, and it is still on the circuit today. It's 29 feet tall, built on a Sherman Tank ch***is, with a 10 ton turntable.
    https://www.google.com/search?q=meg...ate=ive&vld=cid:fc13a334,vid:jly7YOOcWJY,st:0
    Sharpone, vtx1800, das858 and 7 others like this.
  21. squirrel
    People with experience building things can build them without being able to draw them. But when you're working with kids who've never done anything remotely related to designing and building a machine, you have to start somewhere. I like to start by getting them to make a sketch, and yes, it does take a while before they figure out how to do this.
    the point is that if something can't be drawn (by even a skilled draftsman), it's not likely that it can be built.
    Sharpone, das858, clem and 5 others like this.
  22. Frames
    Frames
    More A S A cars. Darrel Waltrip and Alan Kulwicki. NASCAR S W Tour 1987 champ, Roman Calzinski. And I think NASCAR N W tour champ 1987, Don Dowdy. Car featured in Stock Car Racing magazine.
  23. proartguy
    proartguy
    from Sparks, NV
    The chalk lines on the floor work. We used masking tape which lasted pretty well.
    Having some of the problems worked out on paper helps prevent expensive mistakes to me and not add to the s**** pile. We had to do plans for projects when I took metal fab in high school in the ‘60s, so it seems normal to me.
  24. Frames
    Frames
  25. Frames
    Frames
    bttt
  26. Marty Strode
    Marty Strode
    Sharpone, Ziggster and saltflats like this.
  27. squirrel
    GM guys working on the design of a car, circa late 1950s....
    Sharpone, clem, lake_harley and 4 others like this.
  28. BamaMav
    BamaMav
    from Berry, AL
    Yup, I'm the same way. I can make a drawing of what I want, but it's never straight or in scale. I can see it in my head though.
  29. Dave G in Gansevoort
    from Upstate NY
    So you guys as old as or older than me, do you remember drafting cl***es long before the advent of the pc? For me it was late 60s, and I wish I had the final project from one of the years. It was done on linen. In India Ink. Half the year's grade. And when you got it back, you could wash it in your mother's washing machine and have a drawing on a handkerchief. Big handkerchief. At least I think it was called linen. If anyone remembers what it was, and I'm wrong, let us know. Not that I'll ever do a drawing that detailed again...
    Sharpone, das858, clem and 1 other person like this.
