Hot Rods Who has a Jet English wheel
Discussion in 'The Hokey Ass Message Board' started by Kickstarter, Jan 30, 2022.
  1. Kickstarter
    Kickstarter
    from NC
    Deuces likes this.
  2. X-cpe
    X-cpe
    Looks like what is essentially a bolt with a round head and a short sleeve, a washer and a spacer. What does the legend for the exploded view call them?
  3. alanp561
    alanp561
    That's just a locking bolt with a spacer and washer, right? Why not just get a bolt the right thread, stack some washers and put a lock washer on top?
    Deuces likes this.
  4. greybeard360
    greybeard360
    From what I see, you have your dimensions right in front of you.
    The I.D. of the spacer needs to be able to slip over the pin that has the threaded hole in it and height needs to be the same as the pin. The washer needs to have hole the diameter of the hold down bolt with the O.D. the same as the spacer.
    X-cpe and alanp561 like this.
  5. gimpyshotrods
    gimpyshotrods
    X-cpe, 51504bat and Deuces like this.
  6. 1ton
    1ton
    Piece of threaded rod, cut to length with a nut welded on top.
  7. gimpyshotrods
    gimpyshotrods
    Deuces and Budget36 like this.
  8. gimpyshotrods
    gimpyshotrods
    So, the value of your labor is $0? Raw materials free, too?
    If so, can I start sending you contract work?
    fauj likes this.
