Who has a STRAIGHT 6 in your HotRod? Come On, stand up!
Discussion in 'The Hokey Ass Message Board' started by AHotRod, May 25, 2004.
  1. bbdiamond
    bbdiamond
    from ROY, Utah
    i had a 1969 chevy 6 in my 24 T it was fun. Had some getty up and go. It was mated to a th350.
    [​IMG]<br/>[​IMG]
    [​IMG]<br/>[​IMG]
  2. I've got a 60 over Chevy 250 in my art deco roadster project:
    http://www.jalopyjournal.com/forum/showthread.php?t=291413
    60 over, aluminum flattop TRW pistons, head with boss removed and lump ports installed, big valves, ported, etc. Comp cams .0495 lift cam. Clifford aluminum intake with Edelbrock 400 CFM 4bbl, Clifford tube headers.
    Got a T5 behind it. REALLY scoots and you just can't beat the sound of a split 6 exhaust.
  3. H3O
    H3O
    i have one in my truck and i love the sound. i'm gonna see about gettin another one to put in my truck. i want some more go too and parts for it are hard to find but you just can't beat the sound.
  4. 6narow
    6narow
    IIRC, your '37 originally came with a 228 inline 6. Size was upped to 248 or 248.5 after the war.
    Would be cool if you could find one of those to put in there.
    I think Offy used to make multi-pot intakes for those engines.
    My ol' man had a Motors Manual that should have your truck in it.
    I can check, if you're interested.
    Later (and probably easier to find) 6 was a 258. May be the same as the big AMC 6 (same displacement, anyway).
    ...of course, if you've already got the Chevy mill...
    unsafe6 and bbdiamond,
    LOVE those rods! Hopefully you're still drivin' them.
    ImperialWheelingMachine,
    .060 over?....in a 250?! I'd always heard the only Nova engines you could go .060 over in were 292 truck blocks. The rest were only good for .040 over.
    Interesting.
    6narow
  5. sixes r gay. V- 8 or youre late!
  6. f6fhellcat00
    f6fhellcat00
    1931 sport coupe with a studebaker 6 185 champion. 3/4 race cam and a t5 trans.
      116.5 KB
      114.5 KB
      116.9 KB
  7. roddinron
    roddinron
    Your avatar says it all, looks like you came in, made a smart *** remark and then turned and ran like hell!
  8. SANTO_DIABLO
    SANTO_DIABLO
    Here is my 56 235 in my 51 chevy...
  9. junkyardjeff
    junkyardjeff
    Cant remember if I posted in this thread before and too lazy to look but my 37 chevy p/u has a 57 235 and if I did post it was probably before I installed a T-5 to the 235 and the suspension and brakes upgrade. Jeff
  10. unclescooby
    unclescooby
    from indy
    I can't believe how hard of a time I'm having to find a plymouth flathead finned head. I"m starting to think I should have built a V8. The V8 stuff is everywhere.
  11. Snarl
    Snarl
  12. Actually, you can take them to .120 but it's not recommended for the street. .060 over is pretty common and no problems for a 250 or 292. Don't know about the other GM inlines.
  13. 6narow
    6narow
    Thanks for the info. I'll keep that one in mind.
    Santo Diablo,
    If that engine's sitting in the car in your avatar....oooohhh, baby!.
    Hellcat,
    LOVE that dropped A-bone...AND with the big Stude 6? SUPER :cool: !
    Thanks to all the latest posters for helping to keep this thread alive.
    I, for one, am just lovin' this!
    6narow
  14. 66ChevyGirl
    66ChevyGirl
    from Maryland
    I have a 1966 Chevy Van 230 straight 6, 3 on the tree. Still stock thinkin about replacing it with maybe a 290, built for some more power. doing a complet resto, just getting started though so a long way to go...
  15. 6narow
    6narow
    Welcome to the forum. ALWAYS room for more ladies.
    One thing about the 292 is that it always was a gas hog.
    I've never heard of one, whether car, truck or van, that averaged better than maybe 12 MPG (and at that milage, you might as well run a V8).
    The 250 is just about as powerful and will net you a little better milage.
    I know a stock 230 with manual ****** and some "talish" gears will net milage numbers in the mid-20's range, in a Camaro.
    So figure, upper teens - to - lower 20's MPG range for your van (depending on gearing and tires).
    ...but here's something...
    Starting in the '79 model year, the 250 and 292 were both offered with a 2-bbl. carb.
    This is the "integral intake" cylinder head (meaning the intake manifold is cast as part of the head).
    The 250 picked up some power because of this. Factory listing was 120 HP / 200 ft.lbs. (292 went up to 140 / 235).
    Your 230 shares the same bore size as the 250 and the 292, so that 2-bbl. head will fit like its made for it.
    Should still be able to find 'em in the junk yards. They were made for 8 model years ('79 to '84 for 250 and 'til '86 for the 292).
    Add in a Marine cam (RH'd) and cherry bomb and your 230 should pick up around 35-40 HP.
    Swap the ignition system over to HEI, too. Easier maintainence, better driveability and gas milage.
    Should be worth a couple of more ponies as well.
    If your 230 is still in good shape (or rebuildable, anyway), this might be a less expensive option.
    6narow
  16. 66ChevyGirl
    66ChevyGirl
    from Maryland
    Thanks soooo much for that info. the van sat for over 14 years in my grandfathers yard. i had a buddie of mine with a roll back bring it to my house. went to the parts store got oil and filter, plug wires, distributor, rotor, coil, pcv valve and got a hook up from a friend that works at interstate for a new battery. little bit of gas later and she fired right up. can't kill a six.... My grandfather said when he parked it that it needed a valve job, he was right about that, little bit of smoke., but other then that it runs great!!!!
  17. GoManGo1951
    GoManGo1951
    Count us in!! A fresh 235 will be going in this winter!!!!!
  18. 2$ Bill
    2$ Bill
    Add me to the list! Ford 200 I-6. Dead stock. Easily gets 20+ MPG and they are a very durable motor...easy to work on too if it ever does need service. I strongly reccomend a six because the parts are plentiful for them plus they are usually far cheaper than V-8 stuff. The slender in-line design of these motors give them an old-timey look. Many youngsters think my 6 is much older/antique than it really is. I love 'em!:)
  19. 2$ Bill
    2$ Bill
    This is a super sharp six I saw over the weekend @ Blue Suede Cruise....On old Chevy/GMC six?
  20. 6narow
    6narow
    Bill,
    That's the grooviest little T-bucket you've got there!
    It's one thing for 85 HP to pull around 3000-4000 lbs., but something totally different when it only has to pull 1000-1500 lbs.
    Much way coolness.
    GoManGo,
    SWEET!
    OMC always did use the prettiest shade of blue, didn't they?
    I bet your '51's going to end up being very reet.
    Would love to see a second posting when the project's done.
    66ChevyGirl,
    You definately said a mouthful when you mentioned that you can't kill a six.
    Glad my suggestions were useful to you.
    If possible, grab a "truck" exhaust manifold when you get that head. You'll know it because the outlet will measure 2.25" on the inside (car ex. was only 2").
    According to the factory, that was worth 5HP, right there (and if the parts guy hands you a long one piece gasket for that exhaust manifold, it'll be the wrong one. That manifold takes 6 little oblong gaskets).
    6narow
  21. 6narow
    6narow
    Bill,
    That's a Chevy mill.
    Check the similarity between it and the pics of GoManGo's 235 block.
    6narow
  22. 6narow
    6narow
    Here's some six cylinder action from U-****...
    30's GMC almost looses it at the end
    http://www.youtube.com/watch?v=UOe6OK2vWFk
    '65 Elcar w/ turbo'd 292 pulling 14.41 in the 1/4
    http://www.youtube.com/watch?v=fz2UaM3i-gQ&feature=related
    One wicked '31 Ford!
    http://www.youtube.com/watch?v=GCgI6pJvG8g&feature=related
    '66-'67 Nova wagon with turbo'd 4200 Vortec 6 pulling a 9.31 1/4
    http://www.youtube.com/watch?v=PUESVD-PnLo&feature=related
    '69 Rambler w/ F.I.'d 4.0 litre straight Six doing the Autocross Boogie
    http://www.youtube.com/watch?v=a9K_DcF_CXo
    THE MIGHTY HUDSON!
    http://www.youtube.com/watch?v=8YjrHhXrV8o&feature=related
    Nice runnin' dual carbed 235
    http://www.youtube.com/watch?v=9Uptu7YaPTM
    '71 Nova w/250 does a heckofa burnout!
    http://www.youtube.com/watch?v=eNo9WX9iFos&feature=related
    '78 Argentine Nova w/250 & a single Weber 48 IDA
    http://www.youtube.com/watch?v=NHkJVn9La6A&feature=related
    a pair of '54 Chevy inliners, racin' in Lodi 10/7/06
    http://www.youtube.com/watch?v=5UmQrqzVTwE&feature=related
    Enjoy!
    6narow
  23. rob-redm
    rob-redm
    flathead six in my 49 Ford Business Coupe, have a Edmunds head & intake soon to hop it up !
  24. SlamCouver
    SlamCouver
    from Brazil, IL
    Iv got a 31 Coupester with a studebaker 170
  25. itsa425
    itsa425
    It's a 230
      113.3 KB
      115.7 KB
      113.9 KB
  26. 225, 6 carbs
  27. nexxussian
    nexxussian
    Itsa425, that's a nice jet engine :D. The straight 6 recip power converter looks good too.
  28. sumtinklever
    sumtinklever
    running straight six as well little 170 in my falcon bone stock gets the job done sort of am planning on replacing it soon as it blows oil like crazy but hey it's a start .
  29. luv your set up!
  30. haney
    haney
    from Knoxville
    I've got a '59 235 in my '51. Over the winter it's getting a dual offy with Rochester B's and a split exhaust (I'm a poor college student so I'm having to save my pennies to get the parts). I just put a 3.55 in my rear and I can do 95 with the stock intake and exhaust can't wait to see the performance changes when I switch to duals.
