Who has a STRAIGHT 6 in your HotRod? Come On, stand up!
Discussion in 'The Hokey Ass Message Board' started by AHotRod, May 25, 2004.
  1. hunter lake
    hunter lake
    53 Bel Air, 270 GMC (with a little old school mojo), BW T-5 trans, 57 rear w/3.90 gears
    No road time yet ......stay tuned [​IMG]
  2. AssGasket
    AssGasket
    Why doesn't anyone run Hudson 6's...???
    kiwijeff likes this.
  3. bornwithatail
    bornwithatail
    not a rod but...
    got a straight in my 52 gmc....
    whether it will stay or not, is another question....
    but if it goes... that 6 is goin in a T frame sometime soon.....
  4. Pete
    Pete
    The little six's have a little git'up and go.
    Here's my 235 powered Modified.
  5. Fordman75
    Fordman75
    I've got a 300 Ford that is getting 3 Holley 500 cfm 2V carbs and a 284H Crower cam. It's going in a 64 1/2 Mustang.
  6. glendale
    glendale
    i have a 52 plymouth. that i'm putting a 50 desoto six in. it's the big block striaght six for mopars. it will have a 5 speed, dual carbs and split exhaust.
  7. Harell Los Angeles
    Harell Los Angeles
    Not in my hot rod but my 54. 235 with 3 carbs on a McGurk intake milled head, Balanced rotating ***embly, and the biggest cam i could get. All it needs is a wayne head and its done.
    Later
    H
  8. AssGasket
    AssGasket
    ^^ Are you a D.O.A. fan...???
  9. 2muchstuff
    2muchstuff
    from Eastern KS
    302 GMC, ported head, big valves, 3 two barrel weber carbs, bored .125 over, crane custom grind cam, muncie 4 speed. All going in the 36 Chev. coupe -- or maybe the 32 Chev. coupe that I'm trying to buy?
    Question for the KC guys. In the late 50's there was a car running the drags called 6-Pack-To-Go. Ran a GMC 6. Beat alot of V8's in it's day. Anyone remember the car, or even better, have any photos?
  10. AHotRod
    AHotRod
    2MUCHSTUFF:
    I'm going to email Don Cain and Roger Williamson in KC and see if they can remember the car your speaking of.
    I'll let you know if I hear anything.
    Glenn
  11. Nads
    Nads
    from Hypocrisy
    I've got a '57 235 in my '54 Chevy. It's got two Rochesters on a Nicson intake, Fenton headers and a heat plate for the intake. It has a Saginaw 4-speed of unknown origin and a '57 Chevy 3:73 rear end.
    I drove it to Vegas and back and used 1/2 quart of oil.
    I love that engine, it makes enough power to keep up with modern traffic, but it sure would be better with an S-10 OD ******.
  12. stan292
    stan292
    The first part I bought for my RPU project was a 292 C.I. inline Chevy motor. I already have an Offy 3 single-barrel manifold, and a Mallory dual-point distributor (that I plan to convert to HEI) for it.
    Drivetrain includes a Weber aluminum flywheel (covered by and ANSEN cast-iron "****tershield" bellhousing), a Saginaw 4-speed (with vintage Mr. Gasket shifter), and a '65 Pontiac posi rear end with big 11" brakes.
    The 292 will get all lightweight components, a complete balance job,
    and a ton of headwork (just like with the Chevy V-8s, that's were the "magic" is).
    If you don't think these things will run hard, your just flat wrong. You don't get the rpms like with a V-8, but there's torque to spare (here's some trivia - the 292 Chevy motor has the longest rods of any GM engine, including the mighty 454!) If you pay attention to gearing, the sixes will kick ***! Anyone remember Joe William's altered roadster (Springfield, MO) that held the AHRA cl*** record back in the late 60's? How about Kay Sissel's NHRA E-altered and twin-inline dragster (which, BTW, is still running and winning!).
    Back in '68, I had a '37 Chevy (g***er-style) coupe with a 292 motor built by the same guy who did Joe's. Unfortunately, I sold the car before ever racing it (stooopid!!). Anyway, it had a Dos Palmos 3 two-barrel intake set-up that was really trick. I'd love to find one, but they are VERY rare. Anyone happen to know where one could be found? I'm also looking for a cast-aluminum valve cover (and cast side-covers) from a Mercury inboard motor (actually a 292 Chevy).
  13. AHotRod
    AHotRod
    Stan: Got any pictures of your old car?
  14. blueskies
    blueskies
    from Idaho
    Mine, you've seen it here before...
    '50 Plymouth 218 block bored .030" over, 230 crank and rods, rv cam, mini HEI, Edgy 9:1 compression finned head, Edmunds water heated dual intake with a pair of Holley 5200 carbs, Langdon's tube headers with HPC coating, Obrien Truckers finned goodies, Flatattack oil filter.
    Pete
    <object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/OMukzqkY0Z8&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/OMukzqkY0Z8&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
  15. AHotRod
    AHotRod
    BLUESKIES:
    You have one sweet looking engine man
  16. DIRTYT
    DIRTYT
    from Warren,MI
    heres my new one for chevy... 60 pontiac 261 fenton headers,offey intake dual rochesters. all the rest is stock im building a 235 for a later project. i love these engines!
  17. Bob K
    Bob K
    from Antigo Wi.
    Blueskys, that is one fine looking 6, I love it.
    B [​IMG] B
  18. Jdee
    Jdee
    Great wallpaper 'Flyin' Dutchman'!!!
    anyone ever have one fall off an engine stand?
    [​IMG] [​IMG] [​IMG]Jdee
  19. Revhead
    Revhead
    from Dallas, TX
    running the original flathead 6 in my '49 ford. It runs great even after sitting since '68.
  20. desoto
    desoto
    from Ayer, MA
    265 cube sidevalve six outa a '55 Dodge (big truck, not a pick-up)
    Twin carbs, dual exhaust (factory Fargo truck set-up)
    Accel 300+ ignition, twin remote oil filters and full flow filtration system. Oil cooler (w/ Thermostat so the oil doesn't run too cold) Generator (6 volt) AND alternator (for the cb, radar detector and pre-luber)
    Gets about twenty or so mpg haulin' around a two ton car with 4.30 gears and a '54 Plymouth overdrive.
    hitek likes this.
  21. desoto
    desoto
    from Ayer, MA
    Here's what it's pullin' around
  22. mr57
    mr57
    If anyone wants one of these big Chrysler sixes, 265 cu. in. I got one, rebuilt with low low hours on it. PM me if interested.......
  23. Kojack
    Kojack
    I've never seen a sweeter looking Plymouth motor.
    Wish I still had my inline!
  24. The Bisquits got a 235, but that ain't no hot rod... [​IMG]
    Now that I got a cool garage, I can start working on the bucket, that'll have a Donzies old 216. Does that count? [​IMG]
    Jay
  25. AHotRod
    AHotRod
    AS long as it is COOL, it counts!
  26. hotrodbob
    hotrodbob
    I ran a 218 flat 6 motor in my '48 Plym for about 12 years. dual carbs, Edmunds head, Isky cam, split exh. and 18" gl*** packs. 20+ MPG and 19 sec. E.T. at LACR. got a 200 six for my '63 Ranchero, header, Isky 262 cam and lots a head work. Got Carps lookin for a Aussie 250 Ford head for my '71 Maverick. It's fun to pull a whole shot on a v8 guy and then lift your hood and see him start to babble about fixin his 8. Man they come up with excuses why a 6 will move on an 8.
  27. HonkyTonker
    HonkyTonker
    from Irving, TX
    Running a Straight Six 223 in the 54 Ford. I love it, but I have all the parts to drop in a Y-Block. Gotta love a hot rod that sounds like a sewing machine!
    Buster
    BTLLTW
    Rat Chevelle likes this.
  28. dabond
    dabond
    Well, I am putting a Ford 300" or maybe a 240 into a 41 Chevy PU. The same motor (300" 4 bbl headers) got 17 MPG in an 84 4X4, so I figger it'll do better in a 3000 lb pickup.
  29. My hot rod has a V8 but my mild kustom has a baby stovebolt six! Does that count?
    And yeah, I'm lookin out fer a trick Aussie Ford six head for HotRod Bob to tease SBC owners with.
