Technical Who has the best tri five Chevy Idler Arm? Or should I Rebuild what I have?
Discussion in 'The Hokey Ass Message Board' started by Mitchell Rish, Aug 21, 2025.
  1. Mitchell Rish
    Mitchell Rish
    from Houston MS
    With the import stuff that’s coming in now who has the best idler for the tri fives ?
    One once could rely on a specific brand name but the rebox/ resale gig is alive and well so you never know what your really getting anymore.
    The other choice is to rebuild / etc .Who has been here and done that.
    thanks
    Tow Truck Tom likes this.
  2. squirrel
    I rebuilt mine, both with a stock replacement bushing, and with an NORS bearing. They both have their good and bad points.
    But that was a long time ago, I don't know what's available these days.
  3. Mitchell Rish
    Mitchell Rish
    from Houston MS
  4. primed34
    primed34
    New old replacement stock
  5. 427 sleeper
    427 sleeper
    I'm not sure what bearing Jim's talking about, unless he converted to a poorman's power steering setup. But if the shaft's are in good shape, I'd replace the bushings and call it good, unless it's cheaper to buy a new idler arm, and then I'd be leery of the quality of the new parts, if that was the case.
  6. squirrel
    5window and 427 sleeper like this.
  7. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I am thinking buy the bushing and call it unless like 427 Sleeper said the shafts are worn beyond use.
    rod1 likes this.
  8. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Shafts are not worn. Got the K 377 in. It is shorter than the original. Will that matter?
  9. Mitchell Rish
    Mitchell Rish
    from Houston MS
  10. Mitchell Rish
    Mitchell Rish
    from Houston MS
  11. Mitchell Rish
    Mitchell Rish
    from Houston MS
    Sorry hit it 3 times
  12. Mitchell Rish
    Mitchell Rish
    from Houston MS
  13. Mitchell Rish
    Mitchell Rish
    from Houston MS
    The answer is yes . The part number i should have gotten was K- 379.the K 377 literally split and crumbled.
  14. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I have decided to make my own out of delrin. I can even drill ,tap, and put a grease fitting in it.
    I’ll decide wether to use the inner steel tube or let it run on the frame spindle so to speak.
    427 sleeper likes this.
  15. Mitchell Rish
    Mitchell Rish
    from Houston MS
    IMG_5148.jpeg IMG_5149.jpeg IMG_5150.jpeg Here it is. And I got to admit. I wished I had done it from the git go. Fits the arm super tight and the verticals spindle from the frame mount as well. And I didn’t waste 40 $ buy the time it was shipped to get it. And it’s not imported.
    Algoma56, 427 sleeper and Squablow like this.
  16. Mitchell Rish
    Mitchell Rish
    from Houston MS
    I’ll trim and bolt on and be done with it. Need to get the front end alignment checked.
    rod1 and Algoma56 like this.
