who has the recipe for the molasses mix?
Discussion in 'The Hokey Ass Message Board' started by Bondo Slinger, Sep 2, 2003.
  1. I want to clean up my `35 wires and I`m thinkin` that dippin` `em will produse better results than having them blasted. Anyone got the formula for this? And how long do I leave`em in ther for? Thanks -Ryan
  2. Petejoe
    Petejoe
    from Zoar, Ohio
    here ya go.. molasses
    also go to the search in that website and put in molasses
    quoted from the website..
    A 4:1 ratio of water to molasses. Mix it in fairly warm water.
    Depending on your local temperatures the cleaning takes 7-14 days. Helps to agitate every few days.
    If you can remove all grease and paint off the block it will clean those areas also.
  3. TINGLER
    TINGLER
    Here is the old thread: Molasses INFO.
    I don't mean to be a smartass, but the SEARCH function works.
    Give it a try and you will be amazed..... [​IMG]
    Good luck.
    JT.
  4. Thanks guys. Never even thought of useing the search funtion.-Ryan
  5. themodernartist
    themodernartist
    Yep, it works! This is what I first used on some sheet metal for my Hudson. I am now using the liquid which can be purchased at Nurseries or Feed Stores.
  6. Atwater Mike
    Atwater Mike
    Referred to the Search Function. LOL Got a big blank page, other than
    404 The server doesn't recognize the request.
  7. Because the link is from 2003!!
  8. Is this a record dug-from-the -past episode? We're talking over 10 years here!
  9. mgtstumpy
    mgtstumpy
    20:1. 20 parts water with 1 part molasses works well with the thick treacle variety from the local produce store.
  10. kb cookout
    kb cookout
    I mix 7 parts water to 1 molasses
    you can get molasses at most local farm type stores, or at feed mills by the pound just bring your own containor
    later kb
  11. mcmopar
    mcmopar
    from Strum, wi
    I read on here somewhere 3:1
  12. It is nice to see we can still find some of the great tech posted over the years.
  13. raven
    raven
