Who invented the Burnout (at the drags)
Discussion in 'The Hokey Ass Message Board' started by Billybobdad, Mar 19, 2008.
  1. Billybobdad
    Billybobdad
    Way back when all dragcars pulled straight up to the line and made their run and usually smoked their tires down the track. All of a sudden ('65 or so) every one started doing burnouts (with rosin?). Did something change with the tires or did somebody get a sudden brain flash and figure out that more traction was to be had with hot tires, hence the burnout was invented?
  2. touchdowntodd
    touchdowntodd
    who put the bop in the bop....
    seriously, who cares..............................
  3. Psychobilly351w
    Psychobilly351w
    from 732- NJ
    Good question but who put the Ram in the Rama lama ding dong???
  4. BoomBoom
    BoomBoom
    Lets not forget the Dip DeDip DeDip!
  5. Ryan
    Ryan
    ADMINISTRATOR
    I think it's a valid curiosity...
    When I first started drag racing, we were campaigning a s/c car for Super Shops. Les Figueroa (now top alcohol) came to Texas just to give us a run down on strategy, etc... One of the things he was huge on was the 3-second burnout. Procedure was simple:
    1. Put her 2nd
    2. Engage line lock
    3. Hold RPMs at 5000 for three seconds
    4. release line lock and roll off the throttle
    Les had been at Goodyear and while there they were just finishing up some heat range testing. Together they figured the optimal temp for a tire at a certain launch point. They gathered that the 3-sec burnout was most optimal...
    Those big nasty burn outs you see any bracket or street car perform? Just a waste of rubber? And dry hopping? Hard on components and worth nothing performance wise...
  6. injectedA
    injectedA
    Start googling and reading the history of the “smokers” meets. Which I believe was actually to slow the cars down.
    Something I did learn, Grumpy Jenkins is credited with bringing about the 60’ times. He would pull a new tune-up out into the street in front of the shop and launch, each pull would give them the info they were seeking without running the car through.
  7. DirtyThirty
    DirtyThirty
    from nowhere...
    Depends on the tires, I would think, really...different compounds heat at different rates, the temps that day, the track, tire psi, all kinds of things...I know drag radials and cheaters get greasy if its too long...they can get worse. But...yes, in general, a REALLY long burnout is mainly for show, I figure...maybe the extended burnout, past the line, like nitro/alcohol cars do, is just a tribute, in a way, to the days of no tire technology...?
    and...of course: no front brakes.
  8. touchdowntodd
    touchdowntodd
    its valid for the forum, but probably impossible to trace..
    "who was that man? id like to shake his hand............."
  9. KIRK!
    KIRK!
    The burnout was invented by William C. Burns in 1917. While trying to find a cure for his desperately small ***** he sought out many ways to divert attention from his tiny member. His first successful burnout was accomplished on May 19th, 1917 in Dumosston, IL. The women in attendance were unimpressed.
    Burns is also credited with the invention of the truck lift-kit for use on street-driven trucks during the same time period of experimentation.
  10. ncranger05
    ncranger05
    wow i bout fell out of my chair... thats funny kirk...
  11. Unkl Ian
    Unkl Ian
    I seem to remember some Funny Cars used to do
    two burn outs,before each p***.That was probably early '70s.
  12. dry hops baby.
    i can smell the vht from here.
  13. Russco
    Russco
    from Central IL
    I dont know about the first burn out but the long smokey funnycar burnout is said to have been originated in Springfield IL at Drag City mid to late 60's by Pat Minnick driving for Austin Coil (Chi town Hustler) here is a link to the story.
    http://www.jalopyjournal.com/forum/showthread.php?t=239915
  14. Billybobdad
    Billybobdad
    I always thought that the Corvette was the original small member diversion device.
    I stand corrected
    BBD
  15. Muttley
    Muttley
    He also invented the Spork, solar powered night vision and is Godfather to Chuck Norris.
  16. KIRK!
    KIRK!
    That's the guy.
  17. 40Standard
    40Standard
    from Indy
    Herby, the salesman at the local Goodyear store started the burnout
  18. thirty7slammed
    thirty7slammed
    from earth
    ****in showoffs :D
  19. Straightpipes
    Straightpipes
    Well, I ran in the 19's with my flathead Ford in 1962 and did NOT invent the burnout. This is opposed to the SMOKEY burnout which all of those hanging out at the drivein in the same timeframe may remember.
  20. Shag
    Shag
    Ryan,
    I'll start keeping a count and let you know if I see a difference in my 60 foot times. I usually do between a 3 - 5 count and keep a consistent 1.5 second 60's. If I go less than 3 it makes a big difference.
    One more thing to add to my reference logs. :)
  21. DirtyThirty
    DirtyThirty
    from nowhere...
    Later, they would combine the awesome power of the two, in one place...and they would do it with lots of curly, free-range chest hairs...
  22. Ryan
    Ryan
    ADMINISTRATOR
    Hey... ****... the national event winner!!!!
  23. publicenemy1925
    publicenemy1925
    from OKC, OK
    How about when the big match racers came to town, they would prep the track themselves by sprinkleing rosin all over the launch area then sweeping it down the track to make a groove to run in.
  24. Royalshifter
    Royalshifter
    Moderator
    My brother took alot of drags in the seventies and man did he get burnout.
  25. 6t5frlane
    6t5frlane
    from New York
    First Burn Out............Timmothy Leary
  26. About 1963 wrinkle wall slicks came out.
    Racers learned that the wrinkle walls worked well if they spun em up in a puddle of bleach.
    Hence, the name: Bleach Box.
    No big long burnouts, the idea was to clean the tire, roll to the line and race.
    First time I saw bleach used was at Irwindale where Dyno Don's Comet and Stone-Woods-Cook were having a match race.
    Rumor went they were running fuel.
    The cars were cranking off 9's at around 165 mph.
    Sox & Martin ring a bell for me as the first team to use rosin.
    They did a bit of a burnout, others picked up on it and it became a showmanship thing.
    Most time, burnouts are pretty boring and it holds the race up due to cars that don't need to heat the tires sit in the water and spin the tires.
    Best one I've seen there to date was a Quad at the recent airport drags.
    He spun the knobby little tires until the four wheeler was enveloped in smoke.
    His moment in the sun I guess.
    If you're running a treaded street tire, no way you need to do a burnout.
    Drive around the box and make a p*** . . . there's more to it than simply nailing it and hanging on . . . finesse is what counts here.
  27. injectedA
    injectedA
    Yes, burnouts on street tires are a bad thing.
    If you do HAVE to roll through the water and you’re on street tires you should do a couple of dry hops. If you don’t, once staged the water runs down your tread and comes to rest under the tire patch. The only thing consistent there is that you will spin every time.
  28. 47bob
    47bob
    Then they replaced the bleach with gasoline and did the firey burnouts which didn't last long.
  29. Don't forget that the front tires can remain wet, the rear tires hit the water on the launch and there went your chances for a good launch.
    And a win.
    Another one you have to check for is to make sure your fenderwells are not retaining water and slowly dripping out.
    Seen that one create a few probems.
    'Course, building the right car prevents fenderwell leakage problems.
    Just for the heck of it, a couple of recent pics I found.
    The roadster is pulling hard and the tires are just hazing a bit in 2nd gear.
    Street tires fwiw, drove around the water box as well.
    No burnouts or hops.
    The rear tires, BF Goodrch 285/70R-15 on 10" x 15" wheels.
    30" in diameter.
  30. customcory
    customcory
