Technical Who knows about elctrical temp sensors?
Discussion in 'The Hokey Ass Message Board' started by straightaxle, Dec 15, 2014.
  1. straightaxle
    straightaxle
    I need to find a temp sensor to make a stock gauge in a 73 Corvette work.
    The stock Sender is 1/2" NPT and rated at 72-88 Ohms Resistance At 220 Deg F according to Napa.
    I need the same sender but with 3/8" NPT threads because of the heads on this blueprint motor. (I'm really trying to avoid putting the sender in the intake manifold)
    Any idea on a suitable sender?, or combination of sender and inline resistor?
    I apologize if this isn't on topic, but I'm really in a bind, the tech guys at Standard, and BWD couldn't help me
    -Rich
  2. squirrel
    I had that problem once on an old truck....I took a Standard TS-6 and put it in my lathe, and made is smaller. Works fine.
  3. jcs64
    jcs64
    tap the head to 1/2" ?
  4. Inked Monkey
    Inked Monkey
    Would an adapter from your local hardware plumbing section work? I would think the only issue would be if it doesn't seat all the way....
  5. Dig into napa's "big book" for one that fits your parameters
  6. Inked Monkey
    Inked Monkey
  7. squirrel
    yeah, I went through all the other options, and the fifteen minutes I spent on the lathe were well well worth the effort.
    kidcampbell71 likes this.
  8. Jalopy Joker
    Jalopy Joker
    looked for a thread adapter kit? local speed shop, Summit Racing, Jeg's. hardware stuff has wrong threads
  9. squirrel
    The end of the sender kind of wants to be in the coolant, and a thread adapter will put the sender pretty far away from it.
  10. Jalopy Joker
    Jalopy Joker
    not if you get correct adapter - not everyone has a lathe
  11. squirrel
    kind of hard to get an adapter that will allow a part that is bigger than the hole, to fit into the hole. Hence my suggestion to make the part smaller, so it fits in the hole.
    I know half a dozen guys with lathes, in the small town I live in.
  12. Eslope T
    Eslope T
    Is your reluctance to the manifold location due to the location or do you have to modify the manifold?
    How about a thermostat housing, mounted sender unit . GM used that location for a few years. I have also seen one mounted in the water pump but not sure how well it worked.
    I have always had better result with mounting them in the intake manifold.
  13. aaggie
    aaggie
    A lot of Chevy trucks have the sensor mounted in the top of the thermostat housing.
  14. winduptoy
    winduptoy
  15. squirrel
    Standard TS75. Says in the Standard book that it has a 5/8 thread, and notice it has a tapered seat, just like it's designed to go in a hole for a mechanical temp gauge. Which it is...since the older Volvos have a mechanical temp gauge. Might could make it work, if you use lots of sealer?
    stillrunners likes this.
  16. Inked Monkey
    Inked Monkey
  17. squirrel
  18. straightaxle
    straightaxle
    Ok, I have the Volvo sender on the way. Thanks alot guys
    -Rich
  19. squirrel
    Let us know how the threads fit.
  20. UNF is not pipe thread. Not a good match. Still being as it's brass, it might mangle itself to a seal. Or break.
    Not like I haven't seen something like this attempted before...fail miserably...
    Let us know how this works for you.
